Home > Technical (L322) > clunking first gear |
paul_h_8 Member Since: 09 Jun 2010 Location: North East - England Posts: 256 |
What's mileage and have you had a oil change done? |
15th Nov 2010 9:47pm |
What's your mileage? Gearbox oil should be changed every 60k as per the manufacturer. Ring tes transmissions in westbury? They changed my fluid at a very reasonable rate.
15th Nov 2010 9:48pm |
V8 VOGUE Member Since: 26 Sep 2010 Location: bristol Posts: 31 |
Thanks dan
16th Nov 2010 4:15pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34935 |
i read this on another forum and it wasn't a conclusive fix....but its worth a try, disconnect the battery overnight and the ecu that sorts the gears should reset itself....but your problem might be mechanical not electronical [ just made that word up ] so my tip might be bo**ocks...
16th Nov 2010 4:33pm |
You can try an oil change, it can only help... What happened to your first box? Could whatever caused that to fail be causing problems with your new box? (thinking fluid cooler, overheating, blocked cooler lines etc etc) |
16th Nov 2010 6:15pm |
Booked it in today for a flush and filter,
17th Nov 2010 3:27pm |
