Home > Maintenance & Mods (L322) > Rear Passenger door will not unlock with keyfob |
Is your childlock not activated on that door |
7th Jun 2016 3:58pm |
Declan303 Member Since: 08 Dec 2015 Location: Meath Posts: 151 |
No checked that, Same as far side that does open. As I say, I can open it from inside so not child lock Declan
7th Jun 2016 4:49pm |
EmiratesA380 Member Since: 14 Jan 2015 Location: england Posts: 350 |
7th Jun 2016 6:52pm |
Hi EmiratesA380,
8th Jun 2016 12:16am |
8th Jun 2016 9:20am |
Great help, thanks again. Declan
9th Jun 2016 1:51am |
Anyone got a wiring diagram for the door locks so I can test it before buying a new one just in case its a wiring problem. Declan
18th Jun 2016 11:32am |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16176 |
Declan, do it sooner rather than later sir... Once the latch fails locked you;; be into cutting things open |
18th Jun 2016 11:48am |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7640 |
Don't bother fiddling about with it. I had to replace both rears on my td6...... It'll be the latch.... Fit a new one...... Quick as Craig says....
18th Jun 2016 12:53pm |
Is LR013381 the correct part number of what needs to be replaced. rear passenger side door. I happened to look on ebay and found Range Rover L322 03-09 Left Driver Side REAR Door Lock Latch Actuator CWC500090 so a bit confused Declan
18th Jun 2016 5:21pm |
Anyone know is the latch and the actuator two seperate part numbers or are they all the one unit? Declan
20th Jun 2016 11:20am |
Got sorted, pulled the latch/activator out and part number is CWC000111 which apparently is superseded by LR013381 so new one ordered. Hope the old one holds out till it arrives Declan
20th Jun 2016 5:43pm |
Leave it unplugged until the new one arrives
20th Jun 2016 7:58pm |
Yeah good idea, I didn't think of that. Might just open it again and pull the plug off Declan
21st Jun 2016 3:26am |
