Home > Technical (L322) > Folding side mirror judder
Webbie
This is my first ever post, I' had my 2011 4.4 TDV8 Autobiography for about four months and am very pleased. The car has no major falls at all after, I've done just over 7000 miles in it so far, with 60,000 miles now in total on the clock. But I do have a few tiny little niggles, the first of which follows:
When my side mirrors fold in, there is a slight judder. When the car has been in full sun there is a very distinct judder and the motors sound like they are straining. Is there a simple fix? Perhaps a squirt of lube.
Post #406282 25th Sep 2016 9:37am
mine does that too. passenger side one mostly... Just put a bit of silicone grease on mine, then wiped off the excess. Didn't seem to make much difference There is nothing that can't be fixed with a hammer😜😜
Post #406283 25th Sep 2016 9:39am
bwelton
United Kingdom 2012 Range Rover Vogue SE TDV8 Zermatt Silver
Re: Folding side mirror judder
Unnecessary quote removed
I have had the same problem. I took it in to the Milton Keynes dealer and they said they fixed it, but its bad as ever. I would love to fix it, so please someone help us all out ?
Post #406663 27th Sep 2016 5:46pm
nino_nino
I had same problem and used "CorrosionX" (It was from Haylands that I learned about this product, thanks Haylands Thumbs Up ) it worked great for me.
Post #406681 27th Sep 2016 6:55pm
CS
Mine has this too. I was told by a dealer technician that the lubricant on the post on which the mirror swivels gets pushed off the section used between the driving and folded positions and the thing to do is to push the mirror forwards from the driving position to draw some lubricant back on to the stem. You might want to verify that elsewhere before trying it though. Only Range Rovers since 1988
Post #406787 28th Sep 2016 12:04pm
Webbie
Does anyone know if the whole unit needs to be stripped down and lubricated, or if there a point where the mirror can be squirted with a lubricant such as Corrosion-X?
If a strip down is required, does anyone have a page from the manual?
Post #406799 28th Sep 2016 1:48pm
nino_nino
No striping, I manually folded mirror squirted some CorrosionX.Give couple days for it to work.
Post #406870 28th Sep 2016 9:09pm
Webbie
Thanks for the advice, will give it a go.
Post #406918 29th Sep 2016 7:58am
