Home > Technical (L322) > LPFP L322 td6
littlecub
Australia 2003 Range Rover HSE Td6 Epsom Green
LPFP L322 td6
Just fuelled up got 300yards down road and fuel injectors came up on dash. No power.
Plugged iid tool in and get P1180-04.
Low pressure fuel pump( could be filter it says). Am thinking its the pump not the filter as i change the filter every 2nd service. Roughly 6 to 7 thou oil changes.
Post #421358 6th Jan 2017 12:01am
gregdav
England 2005 Range Rover Vogue Td6 Bonatti Grey
Did you let the fuel run a bit low before filling up?. Below quarter tank, these ff's can suck up some crap out of the tank.
so could still be filter, or some crap in l/p pump.
go cheapest and easiest first.
Greg.
Post #421365 6th Jan 2017 7:47am
littlecub
Changed the filter and after a bit of coaxing it started. stopped, started, stopped,started and got it running.
Went inside to get ph so I could clear the codes on iid tool,when I came out it had stopped. Crying or Very sad
Tried to start it again but after a few goes nothing. Couldnt hear the pump.
code P1180-04 still up left side fuel pressure sensor plausibility, pre delivery pressure below starting required pressure.
general failure info
system internal failure
Any hints and tips greatly appreciated.
Have ordered a LPFP for the one near the rear L wheel.
Thanks
Post #421371 6th Jan 2017 9:03am
littlecub
Update.
Got my bosch pump today. Very Happy
Just waiting for the intank pump to arrive Tuesday then to get them swapped over.
cheers
Post #424057 21st Jan 2017 12:14am
umitbat
A Trap 2010 Range Rover HSE TDV8 Atacama Sand
Seems intank pump is faulty.
Same was here.
Post #424069 21st Jan 2017 9:17am
littlecub
Well I finally got my beast back.
The LPFP was ok,but it was changed anyway.
It appears to be a relay in the rear fuse section that was the culprit.
Changed it for a known working one and I'm back on the road.
Now to get the back seats back in. Evil or Very Mad
cheers
Post #424979 27th Jan 2017 2:21am
Was about to say I change my fuel filter every service as the cost of it is pretty small here, albeit I do 6k services FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #424990 27th Jan 2017 7:25am
Trewy1
England 2006 Range Rover Vogue Td6 Barolo Black
I got a problem starting my td6 I can get it running with easy start it will run properly until I give it a good boot it will loose power and once I turned it off it will not start again can anyone point in the right direction
Post #460288 11th Dec 2017 9:04am
High pressure pump is dead I bet.
Should be giving a low pressure warning on diagnostics I bet. This is why it won't start without easy start as it needs the higher crank speed to get pressure up and then still has no power and will stall easily FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #460474 12th Dec 2017 9:21am
miggit
When I had the doesn't want to start symptoms it was 2 knackered injectors Shocked once i'd limped home and had them all cleaned, tested and repaired as required the car never missed a beat! Yesterday I couldn't spell Engineer... Today I are one!
Post #460500 12th Dec 2017 11:05am
