Home > Technical (L322) > Drivetrain hum/vibration? V8 2003 |
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1341 |
Have a look at the centre support bearing in the middle of the split rear propshaft. Only Range Rovers since 1988 |
24th Feb 2017 1:43pm |
Ollie7195 Member Since: 11 Dec 2016 Location: Somerset Posts: 74 |
Does it get worse on particularly smooth roads at low speeds? also are you running original sized tyres/rims or larger and are they worn?
24th Feb 2017 3:59pm |
JoeRRV8 Member Since: 03 Feb 2017 Location: Yorkshire Posts: 9 |
I'll have a look at the centre bearing thanks.
24th Feb 2017 11:13pm |
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 |
Find yourself a nice slow uphill gradient and hold the throttle at a constant light throttle accelerating very gradually and if the vibration stops at around 60 mph or less and if the Rev counter is moving very slightly in time with the vibration then TC Is My bet, sounds a bit like the rumble strip at the side of the motorway |
25th Feb 2017 3:27am |
Had the car to a gearbox specialist, turned out to be a worn valve in gearbox and a faulty solenoid, drives great now |
30th Mar 2017 9:39pm |
