Home > Technical (L322) > FUEL INJECTION SYSTEM FAILED 14 TIMES |
BOBCUSSEN Member Since: 25 Nov 2012 Location: DORDOGNE Posts: 296 |
just spent half hour typing this fault and tried to submit it and lost the post
19th Mar 2017 2:24pm |
mr_spock Member Since: 07 Apr 2016 Location: Welwyn, Hertfordshire Posts: 311 |
Could it be the fuel pump relay? Maybe stopping a restarting kicks it into action. |
19th Mar 2017 2:32pm |
hi
19th Mar 2017 2:38pm |
HI GUYS
19th Mar 2017 6:59pm |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7629 |
19th Mar 2017 7:21pm |
ah ok
19th Mar 2017 8:02pm |
hi spock
19th Mar 2017 9:25pm |
If it were mine, I'd swap the relay then leave it idling for an hour with the heated seats on. If they switch off, the relay is dying. If it idles for an hour, drive it home and put up with the risk of a breakdown. Keep your credit card and the number of a transport service! Will be cheaper than a pump. |
19th Mar 2017 9:54pm |
G62 Member Since: 16 Mar 2017 Location: Bergen Posts: 12 |
I had similar symptoms. Engine stalled while driving, fuel injection fault displayed and car restarting quite quickly. Happened now and then in the begining, then more frequently. Turned out to be the in tank fuel pump giving up. When it finally gave in the fault would come near half tank every time. Bought just the electric pump (from original manufacturer) and replaced. Cost around 40 GBP+ two hours. |
19th Mar 2017 10:26pm |
hi spock; ok that sounds an idea; where is the relay located , did you say its in the rear fuse compartment ? and also the other suggestion that it might be the tank electric pump, sounds possible worth a try, i cold ask them perhaps to change that, which would mean that and the secondary pumps have been changed, and then as you say take the chance and take it home; ,? i have after all managed to get it over about 500k albeit with 14 short stops; worth a gamble rather than just changing the main pump which might be ok anyway bob |
19th Mar 2017 11:14pm |
would the fuel tank have to be dropped from the car if i choose to do that or is it accessed from inside the car ?
19th Mar 2017 11:20pm |
just another thought but perhaps it may be the relay, and is failing because it is getting hot ? which would explain that i first was able to drive 300 K BEFORE the first breakdown, and over 100 K on the way back, before it went again, both at high speed spells on the motorway ??
19th Mar 2017 11:27pm |
the fuel pump relay that you are referring to, what pump is that , the in tank pump or the secondary,? also just so i can understand what pump does what, am i correct in thinking the in tank pump, pumps to the secondary pump, then the secondary pump boosts the pressure and then sends fuel to the main pump;??? in that how it works; i ask because the first garage it went to who changed the filter etc, said the main pump supplied the secondary pump, and they suspected the main was at fault?? they were not a dealer !! |
20th Mar 2017 8:39am |
The in-tank fuel pump moves fuel from the LH side of the tank to the RH side were both the in-tank pump and the fuel supply pipe sits. The seconday pump is responsible for the low pressure side delivering fuel from the tank to the filter. If the in-tank fuel pump fails completely it will mean you only get to use half of the tank volume, that it what is in the RH side if the tank since it is a saddle type with one part on eiter side of the rear propshaft. RH here is passenger side on a LHD car.
20th Mar 2017 8:55am |
