Home > Maintenance & Mods (L322) > Advice on fitting brake pads |
Webbie Member Since: 02 Apr 2016 Location: Corby Posts: 137 |
I fitted new disks and pads to my MY2011 TDV8 a few months ago and did not grease the back of the pads, as they had the self adhesive high density foam pads on the back. I now have deep tone break squeal with low speed braking.
20th Jun 2017 2:17pm |
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 |
are those original disks and pads or aftermarket? |
20th Jun 2017 4:32pm |
Genuine Land Rover from Dan at Duckworths |
20th Jun 2017 4:43pm |
will give it a try in the morning. better than striping them all down again. |
20th Jun 2017 5:33pm |
Tried the hard breaking idea, no better. The problems now getting worse, with vibration being felt inside the car.
25th Jun 2017 8:52am |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3193 |
Sounds more like a sticking caliper if you are getting vibration. Check the slide pins and re grease them. Alternatively, is there a warped disc? Unlikely as they are new but..
25th Jun 2017 9:00am |
Thanks, will give that a try this, I had not thought to grease the pins. While everything in apart, should the back of the pads be greased or left dry? |
25th Jun 2017 11:32am |
I would put a very light smear on the back. John
25th Jun 2017 1:00pm |
alfapat Member Since: 09 Apr 2017 Location: Elgin Posts: 349 |
use a white lithium grease |
25th Jun 2017 1:35pm |
where is vibration coming from? front, rear, left, right. is it always present or only under hard braking? if you trailing the brakes do you feel pulsation on the pedal? |
25th Jun 2017 2:25pm |
The vibration is coming from the front near side. It only happens at very slow speed, like a couple of miles per hour, with very very light touching of the break peddle. Firm pressure to the peddle gives no squeal or vibration. Typically occurs when slowing the car in slow rolling traffic. No binding on the breaks at all. Car stops well and otherwise everything is in order. |
25th Jun 2017 5:28pm |
No need to grease the pins on the front calipers, it is rear caliper that have sliding pins which require greasing.
25th Jun 2017 7:47pm |
Thanks again for the reply, the old disks we totally shot and have been skipped. The new ones were true when that were fitted, but I just bolted the new disks on without cleaning the mating surfaces, so I guess that could well be the problem. |
25th Jun 2017 9:31pm |
stu Member Since: 04 May 2011 Location: Richmond North Yorkshire Posts: 927 |
It's not unheard of to have warped new discs! I had a set when I did the discs on my 3.6. Pain in the ass finding out they are damaged and having to by and fit a new set before returning the warped ones..
26th Jun 2017 6:56pm |
