Home > Maintenance & Mods (L322) > Driver Seat Leather Repair
scotcruz
Scotland 2010 Range Rover HSE TDV8 Zambezi Silver
Hi folks,
My job for today was to repair the scuff at the side of the driver seat which i wanted to do before it got worse.
Bought the kit below which got delivered this morning:
http://www.ebay.co.uk/itm/332221616850
Looked like the previous owner didn't care much
Step 1: use 1200 grit sand paper to ensure surface is smooth without any rough ridges.
Step 2: I could have got away without using the filler but I chose to apply a thin layer of filler as it's subject to wear. Use masking tape to protect the plastic trim.
Step 3: Allow to dry for 10 minutes (I used a hair dryer) then use the 1200 grit sand paper to smooth the surface
Step 4: Clean the surface with alcohol cleaner and apply the Base coat. Below is the first coat.
The result: I applied 4 coats.. applied them using the foam pad supplied on a dabbing motion
Really chuffed with the results and saved myself a fortune.. A leather specialist wanted £75 for it.
Hope this helps.. if you have any questions feel free to ask. Current:
- L560 Velar HSE R-Dynamic D180
- Peugeot 508 2011 - 2.2 HDi GT
Past:
- FFRR V 2010 - 3.6 TDV8
- Citroen C4 1.6i Petrol
- Mitsubishi Shogun 3.2 DID
- Peugeot 607 2.2 HDi
- Nissan Primera 1.8 SVE
- Honda Civic 1.6 VTEC
Post #443233 1st Jul 2017 5:51pm
stu
United Kingdom 2012 Range Rover Vogue TDV8 Orkney Grey
Top job mate!... Thumbs Up Current: TDV8 (3.6) RRS HSE
Past: TDV8(4.4) Vogue
Discovery 3 Commercial
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #443235 1st Jul 2017 5:54pm
GGDR
Top job that Scot!
. Cheers, Greg
Post #443240 1st Jul 2017 6:31pm
