Home > Technical (L322) > rear window issue |
hamlet Member Since: 18 Nov 2016 Location: Kildare Posts: 294 |
Is this from using the switches in the front or back?
6th Sep 2017 12:58pm |
Flashman Member Since: 05 Jun 2011 Location: Windsor & Brentwood Posts: 1227 |
Could be an issue with the body control module under the passenger seat. Sometimes the circuitry/resistors can fail or connections can get loose.
6th Sep 2017 1:57pm |
vmaxer Member Since: 22 Jun 2016 Location: staffs Posts: 110 |
Sorry from using front the not had chance to try back as I have to put the lock on |
7th Sep 2017 2:10pm |
Just so I understand, using the switch in the front, the rear windows will go down but won't go back up?
7th Sep 2017 2:51pm |
hi no as soon as i put ignition on the rear windows go down so i havto leave the rear window lock on ,then sometimes rear windows will come down as im driving so stop car hold rear window switches at front of car and turn ignition on and pray |
7th Sep 2017 3:00pm |
Sounds like there's either a short somewhere (switches?) or a problem with the BCM.
8th Sep 2017 4:32pm |
ok thanks will be gettin stuck in as soon as it stops raining |
9th Sep 2017 4:33pm |
Balloonengineer Member Since: 03 Sep 2017 Location: Kent Posts: 171 |
I had a stuck rear window recently. Pulled it down manually with a flat hand while holding the switch.
10th Sep 2017 10:26am |
thanks but it was the first thing i did |
10th Sep 2017 11:40am |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 7908 |
I'd plumb for the BECM, they have small relays on the PCB which fail...
10th Sep 2017 12:06pm |
