Home > Maintenance & Mods (L322) > Coolant level fluctuating and viscous fan on more often ? po |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2213 |
I had the above and also the heater stopped working anyway lots of messing around and removed the thermostat put in new one exactly same so removed thermostat and will get yet another from landrover but once the thermostat was removed all quiet and the heater has started to work again so if you have the above symptoms and they do seem common it could the the thermostat on the way out |
21st Oct 2017 11:47am |
bembo449 Member Since: 26 Jul 2017 Location: lincolnshire Posts: 799 |
so your saying the stat you got was faulty then pal ? |
21st Oct 2017 12:56pm |
Yes genuine landrover stat put it in without testing it - assumed it was good - bottom hose didn't warm up this morning so hooked stat out popped it in a pan of boiling water and no movement nothing but it did let out a couple of air bubbles so yep it goes back for a swap |
21st Oct 2017 1:08pm |
its not unheard of for a new stat to be faulty pal |
21st Oct 2017 1:09pm |
True had them before |
21st Oct 2017 1:12pm |
just irritating as pal . . . . . |
21st Oct 2017 1:13pm |
