Home > Technical (L322) > Webasto T91 changing to heat question |
berkshirelad Member Since: 06 Apr 2016 Location: Newbury Posts: 265 |
This is the part ( that you will need if after stripping and cleaning yours it is no better.
2nd Dec 2017 9:17pm |
Zeppfish Member Since: 28 Feb 2016 Location: Surrey Posts: 57 |
Guys try an error lockout reset of the FBH and see if that works! I have taken the following from the webasto workshop manual
3rd Dec 2017 7:00am |
Gumball3000 Member Since: 11 Mar 2017 Location: Liverpool Posts: 200 |
Another update.
3rd Dec 2017 3:33pm |
Following the last post , i have checked my heater and it doesnt blow at all when it set on auto mode but is fine when you manual press the direction buttons.
3rd Dec 2017 5:23pm |
TOF Member Since: 13 Mar 2013 Location: Gloucestershire Posts: 53 |
I have just purchased the keyfob for my 2011 vogue, and i am dreading trying it. I always get the low battery warning even when i open the door from being parked up. Had a new agm battery a couple of months ago, and seems no better with the low battery warning issue. Seems a bit pointless putting a heater on a car like this that is meant to run for 30 mins, when the system will shut it down after 4 mins even with a good battery. |
3rd Dec 2017 10:00pm |
