Home > Maintenance & Mods (L322) > Windscreen replacd today - possible problem. |
Andy Member Since: 24 Feb 2009 Location: Shropshire Posts: 2926 |
Autoglass came out to fit my new screen today. Took longer than anticipated as the scuttle plate had previously been bonded onto the original windscreen and they had to cheesewire it off. Not sure if it was done at the factory or not. The scuttle plate now has to be replaced thanks to whoever bonded it on.
17th Jan 2018 6:57pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34914 |
there is a gap, i hide my dashcam cable up there but you'd have to pull it down a tad to get fingers up there... ... - .- -.
17th Jan 2018 7:14pm |
I can grab the rooflining with the tips of my fingers and pull it down. Nothing seems to be holding it in place. Seems like it needs press clips or something |
17th Jan 2018 7:17pm |
millerj90 Member Since: 25 Oct 2010 Location: Melksham Posts: 332 |
Andy
17th Jan 2018 7:19pm |
Funny you should say that- When I looked at it with the screen out, I was tempted to shove my dashcam cable inside the void between the lining and the shell before the screen went back in. |
17th Jan 2018 7:25pm |
So- anyone else have the same issue? |
18th Jan 2018 3:32pm |
Fatfred Member Since: 15 Dec 2017 Location: essex Posts: 50 |
hi, did anyone have any problems with the rain sensor not working after a screen change, i had mine done in the summer last year and after the rain sensor is not working, any suggestions would be grateful FF TDV8 WESTMINSTER EXTERIOR DESIGN PACK 2012 |
19th Jan 2018 8:37am |
ajac8 Member Since: 04 Oct 2011 Location: Shakespeares County Posts: 1619 |
Did the fitters simply forget to reconnect the elec connector? 405 AB exec seats Baltic and Cirrus
19th Jan 2018 4:38pm |
Bellini Member Since: 11 Jan 2012 Location: Berkshire Posts: 2261 |
The rain sensor and headlight sensor stopped working on mine when my windscreen was replaced a few years ago.
20th Jan 2018 4:22pm |
