Home > Maintenance & Mods (L322) > 3.6 tdv8 egr valves - how often and how much? |
TJH1985 Member Since: 11 Feb 2015 Location: Nottingham Posts: 663 |
Replaced at 83k here, one was just the “positioning sensor” but otherwise mechanically very smooth, the other one was mechanically rough with the little rollers being screwed resulting in a section that stuck or was jerky on diagnostics this one was clearly hunting trying to achieve the comanded position.
3rd Mar 2018 3:55pm |
mrtidy Member Since: 31 Aug 2015 Location: Stockport Posts: 211 |
I've just had both my egr valves replaced at land ranger services in stockport. My car has done 94000 miles when the mil light came on,no other symptoms car ran perfect so I plugged in my iid tool and confirmed problem was egr valve. Landranger replaced them both just under £700 Inc vat parts and labour so very happy with the outcome. So yes in my experience mileage in the 90000s may be the time replacements may be due.
3rd Mar 2018 10:22pm |
DavidL Member Since: 14 Nov 2013 Location: wiltshire Posts: 140 |
Thanks Mr T. That was what Mr M seemed to be saying but as you said I'd be interested to see what the thoughts were on this. The other issue is turbo failure, rather more expensive too. I gather one side is an ok job but the other involves major disassembly. |
4th Mar 2018 12:18am |
kgeddes Member Since: 11 Jan 2015 Location: UK Posts: 289 |
Interesting thread. What exactly causes the turbos to fail on the 3.6 TDV8 and are there preventative measures that can be taken? |
4th Mar 2018 9:51am |
rvbush Member Since: 08 Jan 2016 Location: Leamington Spa Posts: 520 |
Although not RR's, I've owned several vehicles (all turbo diesels, currently an E90 BMW 320d on 130k miles, these are supposed to fail at 80k!)) that are supposed to be prone to turbo failure. My two penn'orth is that it's a combination of stupidly long oil change service intervals (which only benefit the fleet market) and failure to properly warm them up and, even more importantly, cool them down after a run. How many times do you see people come storming into the mortorway service area, park, engine off, out of car and away. That engine (usually a turbo diesel) has just been on the motorway, working hard, with old oil in it and it's just been shut off while pretty damn hot. This can slowly build up a layer of gunk in the turbo around the oil seals, ultimately contributing to failure.
4th Mar 2018 10:11am |
Clive603 Member Since: 21 Jun 2016 Location: Sussex Posts: 35 |
Reckon rvbush has the right of it.
4th Mar 2018 3:26pm |
dolph34 Member Since: 14 Sep 2015 Location: Kildare Posts: 1724 |
Had a few Subaru in the past , as with turbo timers that leave carf ticking over for a predetermined time. 2015 4.4 AB
4th Mar 2018 3:58pm |
