Home > Maintenance & Mods (L322) > painting rear exhaust 'box' |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34929 |
done the exhaust and anything else i could under the back of the range ..used wickes 'direct to metal' paint ......... ... - .- -.
5th Feb 2011 1:57pm |
I dont think the rear box gets all that hot. So you should be OK with most paints I guess. |
5th Feb 2011 2:00pm |
nick h Member Since: 26 Jan 2011 Location: notts Posts: 782 |
thanks guys - not as mad as i thought - |
5th Feb 2011 2:19pm |
I have painted loads with any heat resistant mat or satin black paint. Even Barbeque Spray paint is effective as its totally heat resistant.
5th Feb 2011 2:29pm |
Nickj Member Since: 13 Aug 2010 Location: Ipswich Posts: 262 |
I can't stand sight of mine, so thinking about dumping and replacing with custom twin pipes like the supercharger exhaust. Nothing larey, just oem style. Seen Midlands exhaust do set up on ebay for 260 so going to look local for similar set up.
5th Feb 2011 8:15pm |
Not my cup of tea - I think the fact you cant see the pips on the RR is classy. |
5th Feb 2011 8:24pm |
M44K TS Member Since: 09 Feb 2010 Location: North East U.K. Posts: 1325 |
Satin black high temp paint has worked a treat on mine, just give it a quick once over every few months to keep it looking tidy 2006 Mercedes CLS
5th Feb 2011 8:28pm |
But on the supercharger you can just see tips which is classy and cool. I just want a S/C exhaust on my 4.4 really. Do they fit??
5th Feb 2011 8:33pm |
Macdaddy Member Since: 15 Oct 2009 Location: Preston, Lancashire Posts: 466 |
Did mine with matt black exhaust paint from my local autofactors.
5th Feb 2011 8:56pm |
i think all exhaust show the 'silvery metal' bit after a while and it is so easy to put the RR into high mode and walk underneath and paint.. ... - .- -.
5th Feb 2011 8:59pm |
daveo Member Since: 21 Oct 2009 Location: london Posts: 2307 |
i used satern black paint, the box does not get hot at all, just give a going over with wire wool and your ready to go...looks the part when done, when i am ever behind a rr i always look at there back box...
5th Feb 2011 11:03pm |
That looks superb! Did you remove the box to paint or leave in situ. What pipes have you added and where from at what cost if you don't mind me asking!!
5th Feb 2011 11:39pm |
Any more pics from the side maybe? |
6th Feb 2011 10:54pm |
http://www.fullfatrr.com/forum/topic2333.h...arge+trims V8 facelift Range Rover Autobiography 22" wheels.
6th Feb 2011 11:33pm |
