Home > Maintenance & Mods (L322) > Lambda Sensors |
Rewmer Member Since: 14 Jan 2013 Location: Essex Posts: 142 |
Bank 1 has the oil filler cap. Personly I wouldnt mess with it and just buy the correct one. Are you sure its faulty ? You should get a steady .5v reading from the rears when up to tempreture if I remember correctly. No7 - 2003 V8 Vogue |
14th Mar 2018 7:00pm |
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2180 |
They fluctuate between 0.0 to 0.8 - the harder the driving the closer to 0.8 is this bad or good? This seems to be the case on both rear sensors Current stable:
14th Mar 2018 10:03pm |
Sounds good. .8 is rich so when you give it some I would expect them to go rich. No7 - 2003 V8 Vogue |
15th Mar 2018 1:38pm |
ok great - if I have done the rocker gaskets, the pcv valve, the oil breather hoses at the back going to the cyclone and pcv - what else could cause a vac leak? Current stable:
15th Mar 2018 1:54pm |
Is it an air leak or a badMAF? I’ve got some known good figure for the Mac somewhere. I will dig them out and post them up No7 - 2003 V8 Vogue |
15th Mar 2018 6:30pm |
Found them........
15th Mar 2018 8:11pm |
Ok..
16th Mar 2018 2:00pm |
16th Mar 2018 2:09pm |
Worth a go. Those figure are confirmed against two different vehicles. If it’s under reading then the fueling will be lean. Don’t be tempted by a cheap maf, always buy genuine No7 - 2003 V8 Vogue |
16th Mar 2018 5:52pm |
My maf is a Bosch only 18 months old I am going to clean it first if not I will try to warranty it as it has a limited lifetime warranty allegedly- any idea what that pipe is? Current stable:
17th Mar 2018 12:36am |
Right- this may be two problems now...
17th Mar 2018 8:06pm |
Are you running lpg? It’s not unheard of the vaporiser failing and letting water into the lpg injectors or gas into the cooling system. Try by passing the vap and fulling the plug in the lpg No7 - 2003 V8 Vogue |
17th Mar 2018 9:59pm |
Hi I am running lpg and I did run it yesterday but when I had these problems I switched it to petrol only to rule it out. Also vapouriser is only 6 months old so hopefully not that. I bravely/stupidly went for a 40mile drive and it drove lovely water temps were fine - swapped to gas 20 miles in again was fine ... any other ideas? Got the maf out there was a little dirt on the film given it a blast of maf cleaner before bed cleaned it up will get it back on in the morning... any ideas to the random metal sounding noise? Current stable:
17th Mar 2018 10:47pm |
Cleaned the maf - started up flashing eml, dirty idle.. went for a bit of a drive ran fine engine light went off... any thoughts? Current stable:
19th Mar 2018 8:08pm |
