Home > Maintenance & Mods (L322) > Front to Rear Brake Lines |
kbald Member Since: 17 Aug 2015 Location: Leeds Posts: 488 |
Ive replced mine quite an easy job if you can get underneath. Its a common problem and joe90 did an excellent write up guide which i think is in the wiki. Current 2007 TDV8 Vogue Buckingham Blue |
15th Apr 2018 11:05am |
RotternEgg Member Since: 12 Mar 2018 Location: Bucks Posts: 21 |
Thanks for that, thought I'd already checked out the Wiki!
15th Apr 2018 11:32am |
Exactly the same Current 2007 TDV8 Vogue Buckingham Blue |
15th Apr 2018 11:38am |
Zebedee Member Since: 09 Jun 2016 Location: Cheshire/South Manchester Posts: 354 |
Yes, they do run above that plastic trim.
15th Apr 2018 11:49am |
If it helps, here is the link to the wiki entry:
15th Apr 2018 3:20pm |
Andy_J Member Since: 14 Nov 2011 Location: Muir of Ord Posts: 479 |
I have done the job myself following the instructions that Joe90 has referenced in WIKI. If you are Ok with spanners it is an easy job, but it is not a quick job.
15th Apr 2018 9:20pm |
Clabs Member Since: 08 Mar 2017 Location: Watford, Herts Posts: 125 |
I'm with Andy - as you only just bought it, and it is actually leaking, then take it back to the dealer you bought it from and get them to sort it. Current Cars:
15th Apr 2018 9:48pm |
Thanks Gents.
16th Apr 2018 3:31pm |
It's not only the old cars that need attention to brake pipes... These are from a '10 plate I saw today.
24th Apr 2018 8:35pm |
