Home > Technical (L322) > CV Boot |
Serg7681 Member Since: 13 Apr 2018 Location: Aberdeen Posts: 18 |
Is outer CV boot for L322 is expansive repair ?
26th Apr 2018 10:01pm |
OK, thank you very much
27th Apr 2018 4:26am |
Guys, is anyone tried fit a split CV boot?
27th Apr 2018 5:26am |
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 |
I wouldn't use the split ones myself.
27th Apr 2018 8:23am |
j_rov Member Since: 10 Jan 2017 Location: Warwickshire Posts: 385 |
Hi, just had this done...
27th Apr 2018 9:40am |
This is how i did mine, you can undo the hub nut with the wheel on if you can take out the centre cap from the wheel and lower the wheel back down. I didnt have a 400 Nm torque wrench so i used my weight on a big breaker bar and calculated the point at which i needed to stand to get the right torque.
27th Apr 2018 5:08pm |
sorry for late reply Guys๐๐๐
27th Apr 2018 7:05pm |
ยฃ40 for the boot ?? |
27th Apr 2018 8:45pm |
Yep,๐๐๐๐
27th Apr 2018 9:00pm |
Thats not bad then if its the inner and outer as a kit with all the clips
27th Apr 2018 9:10pm |
