Home > Technical (L322) > Head scratching electrical problem
bigbikerrob
United Kingdom 2016 Range Rover Autobiography SDV8 Corris Grey
When unlocking the car usually the splash screen is shown on the touch screen and the power button has the flashing light in it, however lately none of this has worked. Its as if the head unit has no power.
I did the usual of checking the fuse box and found that when I pull out fuse F49 15A from the main fuse box(not blown) and replace it the power is returned and screen works although the radio settings are now reset (stations saved but not identified)
This is now happening nearly every day and it's getting on my nerves.
Does anyone have any insight? All help appreciated.
Thanks in adavnce
Post #489020 16th Sep 2018 2:53pm
i'd consider a battery replacement...
Post #489021 16th Sep 2018 2:55pm
bigbikerrob
That was my first thought. Sadly I only do very short journeys these days and the battery doesn't get much charge time.
Post #489022 16th Sep 2018 3:04pm
DrRob
Hook up a ctek charger to it when not in use. Can be done through towing electrics if fitted. See shop section Thumbs Up 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
New Defender D300 90 on order so "Rory" will be going to a new home....!
Post #489024 16th Sep 2018 3:29pm
