Home > In Car Electronics (L322) > Confused sat nav
SidewaysMatt
United Kingdom 2004 Range Rover Vogue Td6 Giverny Green
Confused sat nav
Hi all,
Acquired a MK4 sat nav unit and fitted it last night. Like a Muppet, thought the gps aerial cable unscrewed (it doesn't you just pull it off). So I kept unscrewing and ended up with a very twisted cable, eventually felt like the innards of the cable gave.
Noticed this morning, the car thinks I'm 197 miles away from where I am. Presumably the address of the previous owner of the nav unit!
How do I confirm I've broken the gps cable? Is there a hidden menu showing the signal details? 2004 Vogue TD6 - Remapped Smile
2008 Porsche Cayenne S
1998 Lotus Elise
Post #489074 17th Sep 2018 9:55am
SidewaysMatt
Just to answer my own question, found the relevant hidden menu. Go into settings, then hold the menu button down for 10 seconds. Select sensor check. Showed communication with 6 GPS satellites and a location lock. Exit that and all is well 👍 2004 Vogue TD6 - Remapped Smile
1998 Lotus Elise
Post #489150 17th Sep 2018 8:34pm
