Home > Technical (L322) > Newbie question on residual heater/ parking heater/ FBH what |
AJGalaxy2012 Member Since: 11 Jun 2018 Location: Gainsborough Posts: 1459 |
I have exactly the same situation, apparently caused by the battery. If I connect my battery charger then it all works as it should, you probably need a new battery even though it starts the car OK. BMW i3 Electric Car
1st Nov 2018 7:34am |
Try the remote heater in the morning. When it’s cold.
1st Nov 2018 8:31am |
Lester Burnham Member Since: 12 Sep 2018 Location: North Posts: 116 |
Sorry for my typo in the initial post where I said the parking heater pumped hot air I meant COLD. Northernmonkey - the instruction book says this is activated by pressing the MAX AC button after you switch off. I have never been able to get this going?
1st Nov 2018 10:12am |
Jomo Member Since: 26 Mar 2018 Location: Maidenhead Posts: 32 |
My fbh finally sprang to life last weekend after I replaced the car battery. Before that it had never fired up, even when the battery was plugged into a CTEK charger. It would just blow cold air for 30 minutes with no sounds of it trying to ignite. Without the charger I'd get a low battery warning after a couple of minutes and the fan would switch off. Not sure if it was the condition of the battery or disconnecting the power that made the difference. I've read on here that 3 failed attempts can cause it to disable and disconnecting the power can reset that. 2011 5.0 S/C |
2nd Nov 2018 12:15am |
Interesting about the 3 failed attempts thing - I had a feeling there must be some kind of reset procedure. Is there a hard restart feature on these cars or do you just disconnect the negative terminal for a few hours?
2nd Nov 2018 12:19pm |
I believe (but check for yourself) that the hard reset of all the electrical gubbins is done by disconnecting the battery leads and touching them together. I didn't need to do that to get my fbh working again.
2nd Nov 2018 1:09pm |
As said above no point in expecting it to work at 9c it needs to be about 4c and under to work properly... |
2nd Nov 2018 1:29pm |
kooky_guy Member Since: 25 Nov 2011 Location: Sandhurst, Berkshire Posts: 385 |
You can reset it by pulling the fuse. 13E, apparently on the 2010 on models. 2010 4.4 TDV8 Vogue SE |
5th Nov 2018 3:53pm |
Thanks. Desperately waiting for another sub zero morning to find out for sure!
6th Nov 2018 10:26am |
If it's an AGM battery, is your ctek on the right setting? 2010 4.4 TDV8 Vogue SE |
6th Nov 2018 12:49pm |
The CTEK 5.0 has an AGM icon/LED and it should detect one automatically. I have not physically checked the battery label myself for this as its a bit tight in the jamb to get your head in! I thing Landrover could have made the vertical bonnet feature a bit easier to access... |
8th Nov 2018 3:19pm |
Mines a ctek 3.6 and it doesn't switch automatically. I'm not entirely sure it charges an AGM properly as it never seemed to complete but my battery was quite old. 2010 4.4 TDV8 Vogue SE |
8th Nov 2018 8:06pm |
