Home > Maintenance & Mods (L322) > air suspension inactive? |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6399 |
You may not have noticed that all your EAS lights on the dash have gone out ?
29th Jul 2018 5:47pm |
Northern lad Member Since: 30 Jun 2018 Location: South London Posts: 56 |
thanks Joe
29th Jul 2018 5:53pm |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7635 |
Electronic Air Suspension.....
29th Jul 2018 7:36pm |
thanks for clarifying, the knob by the handbrake? (when I say knob by the handbrake, no I don't mean the driver ) if so, no lights at all on that?
29th Jul 2018 7:59pm |
On the dash....tells you what height suspension is at (though it’s not lit on this pic)
29th Jul 2018 8:12pm |
The light is lit on this pic....
29th Jul 2018 8:23pm |
bruno22rf Member Since: 08 Mar 2018 Location: milton keynes Posts: 69 |
If it turns out to be your pump then I have one here that you are welcome to - took it off my 04 4.4 as I thought there was a problem with it but the fault was not with the pump - I have put a new seal on it just to make sure - Im near Milton Keynes so if you want to pop in and fit it then you are welcome to it - takes about 20 minutes to fit. |
30th Jul 2018 12:42am |
thanks chaps for your replies, and apologies for my delayed response
31st Jul 2018 5:10am |
If the lights are out you have a hard fault. It is a Range Rover, nothing as simple as a fuse - although it does happen...
31st Jul 2018 5:50pm |
+1
31st Jul 2018 6:09pm |
Here if you need it, Steve, 99% sure its good but not sure how old it is although it doesn't look ancient. |
31st Jul 2018 11:57pm |
thanks chaps
1st Aug 2018 7:38am |
Don't want anything for it Steve. Maybe a couple of quid next time you pass a charity box. |
1st Aug 2018 8:25am |
that's very decent of you Bruno, much appreciated, I happen to work for a charity, so consider that a done deal
1st Aug 2018 8:36am |
