Home > Maintenance & Mods (L322) > pressure washing |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34915 |
the clue is in the title nick, water under pressure....it will find any opening into the range and will get into the many electronics we have ...in fact pressure washers will take off paint in some circumstances...
2nd Mar 2011 2:35pm |
nick h Member Since: 26 Jan 2011 Location: notts Posts: 782 |
thanks Stan
2nd Mar 2011 2:48pm |
Nick, what filter are you using? I've been looking at the in-line jobbys but can't find one with high flow rates. Or should I just be rinsing at the end with it?
2nd Mar 2011 3:09pm |
thanks Dan i have the DF Peerless water filtration system cost in 2007 was £118 inc discount it has two 'chambers' one with a salt rechargeable filter the other with a 'cotton' filter it is supposed to give a rinse that is totally free of water spots/streaks not used through the pressure washer but through the hose at low pressure - final rinse worth the money - most certainly not imo - it was aimed a detailing nerds with more money than sense in fact before i bought it i used the Flash system that had simple replaceable cartridges that were in fact better - still using this as i bought a job lot of cartridges when the system was discontinued tbh - just use tap water and whilst still damp apply megs quick detailer - better job |
2nd Mar 2011 3:19pm |
tboner001 Member Since: 22 Jan 2011 Location: Bucks Posts: 691 |
This really depends on how hard your local water is if it is a warm day you cannot get all the water towelled off a Rangey fast enough to stop hard water marks. I use a large water but filled with water via a filter and then pour this over the car as a final rinse can let the car air dry and no water marks Far to many gone... |
2nd Mar 2011 6:08pm |
