Home > Technical (L322) > Dead car |
dolph34 Member Since: 14 Sep 2015 Location: Kildare Posts: 1724 |
Any electrical activity?? 2015 4.4 AB
13th Dec 2018 7:06pm |
cass Member Since: 12 Oct 2011 Location: northumberland Posts: 696 |
Assuming you've ruled out the obvious (battery/terminals) my first guess would be the ignition switch, I've changed one and it seems to be an increasingly regular occurrence, the fact that the main dealer had one in stock suggested to me that they must have needed a few? |
13th Dec 2018 7:08pm |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3954 |
The deep water won't have done your alternator any favours and your car is after all a 2007, the jinxed year for alternators. |
13th Dec 2018 7:11pm |
chefkenmore Member Since: 11 Jan 2015 Location: Fearnan perthshire Posts: 702 |
Interior lights still work, hand brake light on dash works!
13th Dec 2018 7:50pm |
Have you checked voltage of battery ? 2015 4.4 AB
13th Dec 2018 8:19pm |
12v then14.6 when car starts 2014 vogue se |
13th Dec 2018 8:21pm |
I've had a ' google' and a few peeps mention the battery earth strap may be the culprit, some ran a earth grade cable from the negative terminal to the engine block. 2015 4.4 AB
13th Dec 2018 8:49pm |
My Range Rover is in the best place in Scotland! Mike Park MMP, but unfortunately Mike is so busy (been there two weeks!) that he can’t get to it!
13th Dec 2018 9:31pm |
You could try a jump lead to check that. |
13th Dec 2018 9:42pm |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2217 |
Is it cranking ? |
14th Dec 2018 1:19am |
Yes it’s cranking 2014 vogue se |
14th Dec 2018 9:43am |
Ok so that takes out the battery harness as culprit - is it damp under drivers seat think the ECU is mounted there mine did something similar but not so severe and it just needed drying out it was a while ago when we were flooded I put a small dehumidifier in over night - have a look at the ecu and see if it is damp |
14th Dec 2018 9:58am |
Thanks sandt,
14th Dec 2018 10:20am |
Fixed!
14th Jan 2019 6:21pm |
