Home > Maintenance & Mods (L405) > Seat Arm Rest Fix Anyone? |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7764 |
Tension ?
17th May 2019 7:52pm |
carlos50 Member Since: 03 Feb 2011 Location: North England Posts: 717 |
Sorry, what Im trying to describe is the mechanical motion you can feel if you had the rest upright out of the way then pull it down to use as an arm rest, its gone floppy and just drops down.
17th May 2019 7:56pm |
I'll have to test mine - I never really move it - but I guess if it's different to the passenger side then there's a problem |
17th May 2019 8:00pm |
Passenger side has a nice light pressure feel to gently lower it down but doesnt continue to fall if you take your hand off it, mine just flops to the low point thats its set to, no or very little resistance |
17th May 2019 8:02pm |
If you can't fix it, then these may be worth a punt to butcher..... |
17th May 2019 8:08pm |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3195 |
This might help as to how to access it.
17th May 2019 8:21pm |
I was looking at those seats earlier strangely enough, will look around the rest over the weekend see if it becomes clear how to remove it? |
17th May 2019 8:26pm |
Those seats have to be close to worthless once you realise the airbags deployed.....
17th May 2019 9:02pm |
Yeah possibly too much work just to change an arm rest |
17th May 2019 9:27pm |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16175 |
Hopefully this might help sir...
17th May 2019 11:19pm |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3679 |
This is L322 info on armrests, but it might be similar to L405?
18th May 2019 8:46am |
Felstmiester Member Since: 06 Apr 2019 Location: Hertfordshire Posts: 262 |
Happened on our discovery. Just tighten the bolt up that holds it on the seat. |
18th May 2019 12:23pm |
The T27 was rock solid so think the mechanism inside must be broken and its made the arm rest a bit floppy, will live with it for now
26th May 2019 4:42pm |
Carlos, if you have the necessaries? Remove the securing screw and the armrest simply pulls off... If you look at this video
27th May 2019 5:19pm |
