Home > Technical (L322) > Dodgy Starter? |
MartinD Member Since: 20 Oct 2010 Location: Edinburgh Posts: 303 |
New battery ordered from Battery Megastore so hopefully tomorrow she'll be reet! 2011 4.4 TDV8 Vogue SE - 'Black Betty'
22nd Aug 2022 7:05pm |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 2705 |
AGM battery? Also you will need a special security 5 point torx tool to get the ECU out of the way. 2012 TDV8 Vogue (L322) |
22nd Aug 2022 7:09pm |
Yep Bosch S5 and I have the security bits in a set 2011 4.4 TDV8 Vogue SE - 'Black Betty'
22nd Aug 2022 7:16pm |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1356 |
Also check the alternator is charging properly, and was not the cause of a dead battery.
22nd Aug 2022 10:23pm |
That's the first thing I did after he started it - got IID plugged in. Loads of random codes cleared out and then on to Live Data for the battery/voltage. Was sitting around 14 and increased to around 14.3, 14.5 when revving so I think the alt is fine.
23rd Aug 2022 6:38am |
