Home > Maintenance & Mods (L322) > egr blanking kit for td6
Page 5 of 15 <123 456 ... 131415>
GregP
United Kingdom 2002 Range Rover HSE Td6 Adriatic Blue
Again very promising
Looking forward to getting mine fitted now. FFRR TD6 HSE
Adriatic Blue with Parchment leather.
Post #76568 17th Aug 2011 2:06pm
agreed but remember its only the vacuum pipe i've removed and blocked..
Post #76570 17th Aug 2011 3:38pm
BigJ
United Kingdom 2005 Range Rover Vogue 4.4 V8 Stornoway Grey
nicedayforit wrote:
BigJ wrote:
In addition to blanking it any good engine mapper can stop the EGR signal being sent to open it and force it to stay closed at any time.
Assuming the egr valve isn't jammed open in the first place which they frequently are.
On a diesel these valves are usually so gummed up by 50k they don't work anyway. If you are lucky the valve is jammed shut and not passing exhaust gases so no need for a egr replacement kit, if you are unlucky the valve is jammed open or partially open in which case the build up of gunge in the inlet manifold continues unabated.
It's definitely worth taking the valve off and having a look at it's condition internally and either cleaning it out or replacing it with new or a byepass kit.
Why this isn't in the lr maintenance schedules is beyond me.
Exactly.
The benefit of stopping the valve opening in the map, stops the vaccum (SP!) activating. Keeps it a bit more stock. Blanking plate if you are worried about any gasses seeping though and it's ideal. Used to have:
2005 FFRR 4.4 Vogue - BRC LPG Conversion & Remapped
Now have:
2008 SSRR 3.6 TDV8 - HSE and plenty of toys
Post #77027 22nd Aug 2011 8:01am
DaveAngel
2015 Range Rover Vogue SE SDV8 Barolo Black
Do these plates completly block off the EGR, or just restrict it, i.e. do they have a little hole in? __________________
2015 FFRR SDV8
2011 FFRR TDV8 4.4 - Gone
2005 FFRR TDV6 - Gone
Post #77158 22nd Aug 2011 9:19pm
The plate blocks the exhaust gas flow completely, no hole.
Post #77196 23rd Aug 2011 8:52am
if you do use the blanking kit then you could always sell the egr valve on ebay, thats if you dont want to put your fullfat back as stock..
Post #77197 23rd Aug 2011 8:59am
DaveAngel
Awesome - thanks guys will have a go tonight __________________
2015 FFRR SDV8
Post #77246 23rd Aug 2011 4:08pm
Andy
Ever so slightly cheaper here:
http://www.johncraddockltd.co.uk/products/...w_m57_.php 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #77506 25th Aug 2011 8:13am
Well, have run with the vacuum pipe disconnected for a few weeks, with no discernable difference in performance / behaviour or mpg. So I have put it back on for now, and await a dry day to take the EGR valve off and have a look. .
Post #77509 25th Aug 2011 9:59am
i'm wondering what the vacuum pipe actually does ..does it keep the valve open or closed?
Post #77510 25th Aug 2011 10:04am
It adjusts the valve according to throttle position and load on the engine.
Post #77511 25th Aug 2011 10:12am
so if its disconnected ,will the pressure of the exhaust force open the valve..
Post #77513 25th Aug 2011 10:38am
The egr valve is a spring loaded valve that is normally closed to the exhaust inlet pipe. Application of vacuum opens the valve against the spring pressure.
No vacuum, it should be shut unless it can't seat properly due to gunge.
Post #77515 25th Aug 2011 10:54am
Post #77516 25th Aug 2011 11:01am
The pipe needs to be sealed off so that the ECU does not throw up fault codes
Post #77527 25th Aug 2011 12:39pm
