Home > Technical (L322) > Suspension Fault - advice sought |
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1141 |
If you get a low battery voltage on these cars this causes all kinds of fault indications.
10th Dec 2023 8:09pm |
camcc Member Since: 01 Oct 2023 Location: Godalming, Surrey Posts: 30 |
Thanks! Steering angle sensor reset didn't solve the issue unfortunately.
12th Dec 2023 2:04pm |
A new battery solved the issue! Old battery was down to about 40% charge when I tested it
14th Dec 2023 9:33pm |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 2973 |
It's cold at this time of year and if you don't use your car much, especially on a car that's as heavy on electrics as the RR, it's easy for a battery to become discharged.
15th Dec 2023 12:02am |
knares Member Since: 22 Jun 2017 Location: Perth WA Posts: 701 |
(Varta I1 110AH)what is the cranking amps, mine is 800 RR 2005 4.4 petrol
15th Dec 2023 5:54am |
Thanks! Will try that.
920 |
17th Dec 2023 5:37pm |
