Home > Maintenance & Mods (L322) > [SOLVED] Help - Shorted Ignition Live in Boot! - No Radio?
Damn - with key at position 1 I accidentally shorted the ignition feed in the boot. This has blown something as the live feed is dead and the radio won't come on any more (can't switch to it and no sound). The radio was on when I did it and the sound went off and the OBC switched to the main menu. TV works but no sound.
Any advice? (other than stay away from car electrics in the dark!) .
Post #98571 20th Dec 2011 9:34pm
Stephen.125
2017 Range Rover SVAutobiography 5.0 SC V8 Indus Silver
Ouch!
maybe stupid question, fuses?
Have you d/c the battery for a while to give frightened ECUs a chance to breathe?
Sorry if obvious, hope you get it sorted. Thumbs Up
Post #98583 20th Dec 2011 10:25pm
Well I went for fuses, none seemed to be blown in the back so had a look up front. Pulled no 8 (Radio) but car complained with a loud continuous beep which made me jump and I dropped the fuse down the gap! (lol) Luckily spare fuse to hand. So it wasn't that one Laughing Was raining so gave up and came in by the fire. .
Post #98585 20th Dec 2011 11:02pm
Stephen.125
Don't blame you! Thumbs Up
Post #98594 21st Dec 2011 12:00am
Can no-one help?
All sound gone, radio won't switch on at the MFD, Mode button does nothing, everything else seems to work, red light on on the SatNav in the boot?
Help? .
Post #98686 21st Dec 2011 9:25pm
all i can suggest is fuses or a battery re-boot joe..i recall other members having no sound etc but cant remember the solutions.. ... - .- -.
Post #98689 21st Dec 2011 9:36pm
The ignition live is the purple/white wire going to the big black connector in the boot (daveo's photo Wink)
I'll try a battery disconnect and see what gives....
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  .
Post #98695 21st Dec 2011 10:10pm
You could try removing the purple/white wire and running another fused live to the terminal and see what happens Thumbs Up
Post #98718 21st Dec 2011 10:31pm
It's OK, crisis over Smile
It was fuse 8 up the front (Radio)
Can be confusing though, as the car has an additional theft deterrent on this fuse (which other ones I wonder), so if you pull it when the battery is connected (whether broken or not) it sets off the alarm continuous beep, not beep-beep-beep, making you think it isn't the fuse. So be warned!
I disconnected the battery and checked the fuse which was blown. replaced fuse, reconnected battery, lock to lock radio on! (Mick would be proud!!)
Sorry, was doing this in the dark (as in no light) Thud .
Post #98720 21st Dec 2011 10:39pm
Stephen.125
Nice one Joe. Glad it's sorted for a 20p fuse rather than a ££££ Electronic doohickey.
http://www.amazon.co.uk/Led-Lenser-Head-To...amp;sr=8-4
Father Chrimble maybe?
Mr. Green Thumbs Up
Post #98734 21st Dec 2011 10:54pm
rads
2005 Range Rover Vogue SE Supercharged Tonga Green
Joe90 wrote:
as the car has an additional theft deterrent on this fuse, so if you pull it when the battery is connected (whether broken or not) it sets off the alarm
By heck, that's clever.
How does it know you have removed a blown fuse, unless there is a set of contacts that actually detects the presence of the fuse.
Mysterious stuff, this electrickery!
David
Post #98775 21st Dec 2011 11:36pm
Thumbs Up @ happymadison
and for chavs and rednecks
http://www.airsoftcommunity.it/it/recensio...mp-for-cap .
Post #98776 21st Dec 2011 11:37pm
Stephen.125
Laughing perfect, WRX forest stage lights for a scratter cap
Ah there's a thing; perhaps if you see someone wearing that you can sling a handful of gravel at them?
Nice one Joe.
Steve Thumbs Up
Post #98793 22nd Dec 2011 1:26am
