Home > Technical (L322) > Bought Sport Alloys, Need Help Please Tyres suggestions etc
cliffy
2004 Range Rover Vogue 4.4 V8 Zambezi Silver
Ive treated myself as its Christmas to some sport rims I really like
There the 2011/12 alloys
I need to sort out tyres and from wat I've read on here new bolts as well
I'm after the best place to source the wheel nuts and lockers and wat tyres you guys would recormend I run
I'm keen to know the best profile and setup to run on the RR
Many thanks
Neil
Post #99376 25th Dec 2011 8:15pm
what size rim?...
bolts and lock nuts from ebay.. ... - .- -.
Post #99382 25th Dec 2011 9:30pm
cliffy
There a 20" 9.5J
I'll get in eBay now when I searched I found that I need the 06 onwards nuts as I currently have the black nuts on my 04
Thanks
Neil
Post #99386 25th Dec 2011 10:15pm
good job re the nuts Thumbs Up
the standard 20'' fullfat size is 255/50/20 which fits a 8.5j rim.. as yours is a 9.5j the 255/50/20 wont fit safely , for this rim you need a wider tyre like the RRS size which is 275/40/20....but now you run into another problem where the overall diameter is smaller by 36mm meaning your speedo will be out ie, at 70mph on your speedo you will be running at 67mph .. if you can find one ,a 285/45/20 tyre will have the same diameter as a 255/50/20 . ... - .- -.
Post #99389 25th Dec 2011 11:09pm
cliffy
Thanks for the info fella
I've found 285/50/20's do u think these would b alright as there just a slightly bigger wall?
Thanks
Neil
Post #99391 25th Dec 2011 11:22pm
those will be 30mm bigger in diameter and will be at 73mph when the speedo reads 70mph but taking into account that speedos read low anyway ,you might get a true speedo reading.. ... - .- -.
Post #99392 25th Dec 2011 11:24pm
Original tyres are 255/50/20 with a diameter of 764mm
To keep the same rolling radius you will need to fit 285/45/20 (the diameter is 764mm)
285/50/20 have a diameter of 794mm and at an indicated 70mph on the speedo you will be travelling at 72.74
Post #99393 25th Dec 2011 11:33pm
cliffy
Is there a program or link for this I dont mind my speedo being out by reading lower but higher cud b a issue lol
I've tried googling 285's with no joy Sad
Post #99395 25th Dec 2011 11:42pm
cliffy
What if I run a 275/45 or 275/55 ?? Or even a 60
Post #99396 25th Dec 2011 11:53pm
With 275/45/20 at 70mph on the speedo you will be travelling at 69.27mph
With 275/55/20 at 70mph on the speedo you will be travelling at 74.23mph
Post #99397 25th Dec 2011 11:59pm
cliffy
Cheers fella
Post #99398 26th Dec 2011 12:01am
comports
United Kingdom 2016 Range Rover Autobiography SDV8 Mariana Black
All this talk about nuts and rims makes me feel uneasy.. Rolling with laughter Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #99402 26th Dec 2011 9:36am
^^^ This should ease your pain...... Rolling with laughter Rolling with laughter
Post #99405 26th Dec 2011 11:18am
here you go cliffy, you can work it out for your self..
http://www.alloywheels.com/Tyre_Calculator ... - .- -.
Post #99406 26th Dec 2011 11:32am
marsie
England 2014 Range Rover Vogue SE SDV8 Loire Blue
Running 20"RRS wheels on my 4.4 but have upped the tyre size to 275/45/20. No probs and speedo still spot on Thumbs Up
Paul :shock:
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Paul
2014 Range Rover vogue se 4.4sdv8 Loire Blue
1992 Range Rover Vogue LSE 4.2 Ardennes green
Post #100043 1st Jan 2012 5:11pm
