![]() | Home > In Car Electronics (L322) > No sound |
Undo the two 8mm bolts at the top and it should just slide up and out... Check the big black plug on the top, that's the normal one that suffers with water...
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3986 ![]() ![]() ![]() |
Thanks for that. |
Renegade2 Member Since: 03 Dec 2011 Location: Cardiff Posts: 134 ![]() ![]() ![]() |
Not sure what year yours is but mine is a 2005 and a nicedayforit is ceratinly what you will need. I just changed my TV Tuner and the amp is on the same plate, and it is actually bolted in from behind with four star bolts which you can not get to, it was a bitch of a job but the following might help whihc was one of the guys put on a post for me. if you go to the lnk it has step by step guide of what needs to come out to get that out and its a few bolts etc. Took me about two hours from start to finish
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6431 ![]() ![]() |
Before you get stuck in, worth checking the Radio fuse (no 8, a 5amp, at the front on my '02). I blew mine by accident and it knocked out all sound and the radio itself! .
Definitely not the radio fuse, radio is working, just no sound.
Contraband Member Since: 08 Nov 2010 Location: FIFE Posts: 3700 ![]() ![]() |
Lol.. Just came in to do a search as I am having the same problem myself.. Its Stuck on the land rover sign on the display, red light flashing off/on. Found water on the top Nokia module, so I assume there is water on other components.
Just taken out the frame with Nokia, dvdrom and DVD changer, cheers renegade2 for link. Connectors are all looking fine and clean. I picked up the unit to put it back in and noticed a small puddle. Full of bloody water.
volores Member Since: 04 Nov 2011 Location: Melton Mowbray Posts: 55 ![]() ![]() |
Mine has lost all sound this morning (!!!!??) - was fine last night - had the radio and CD on - get in this morning - nothing......all working fine on the screen, cd counter going up so its playing.....just no sound....almost like someone has flicked the mute button!
Try taking each of the plug connectors off the amplifier and spraying the plugs and sockets with a liberal dose of electrical contact cleaner.
Spoke too soon, sound has gone off again |
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3273 ![]() ![]() ![]() |
Niceday, can you post a picture of your amp. I may have a replacement. Need to see what connections you have. I had 3 broken pins caused by corrosion and had to replace the amp. Took it all apart first to try adn fix but the connector units are not able to be removed AFAIK. in any case would involve a new pin and re-solder with very little space to work in. |
@Dolphinboy
I had this a while back and all I needed to do was a hard reset but disconnecting battery touching leads together and putting back together. He Presto sound restored......(Common fault)
Unfortunately there is a pin broken off in the socket on the amp which happens to be a used, it seems to serve a communication link cable. All the bits are working ok just no sound, if I wiggle the plug I get noise from the speakers.
