Home > Technical (L322) > Headlight up grade
Bozzy1954
England 2003 Range Rover HSE 4.4 V8 Epsom Green
Headlight up grade
Hi all, I have a 2003 V8 Range Rover I bought a set of headlights to up grade the frontend, went to fit them today but the Censored don't fit (the air box is in the way) could anyone tell me which year headlights will fit?? I have the BMW engine which must be different from the Jag engine. any help please. Embarassed
Post #100316 4th Jan 2012 9:16pm
what spec is your range, and why do you want to upgrade your lights? ... - .- -.
Post #100323 4th Jan 2012 10:15pm
mattstevenson2005
United Kingdom 2003 Range Rover Autobiography 4.4 V8 Java Black
Re: Headlight up grade
You will have to remove the air box and replace it with an aftermarket K&N filter, you do realise that you cant just swap the headlight for the newer style, you have to replace the whole front end of the vehicle e.g bumper, crash car etc....
Matt
Post #100346 4th Jan 2012 11:16pm
Bozzy1954
Hi It's 4.4 HSE,Both the headlights on the car are missing the lugs to keep them inplace looks like they have snapped off so I thought I would replace them with the newer all in one lights, why would I replace the bumper it dose not interfere with the lights, when I spoke to the dealership they did not mention changing the air box. I just asumed that the 2008 lights that I have must be different from the 2006 lights.
Post #100358 5th Jan 2012 12:30am
the square shape lights you have on your 2003 are completely different to the headlights from 2005 onwards...if you want to fit the newer ones then you have to replace the bumper ,bumper backplate and grill...there is a write up in the wiki re this... ... - .- -.
Post #100360 5th Jan 2012 1:18am
landyash
2007 Range Rover Vogue TDV8 Java Black
Hi like already said its quite a big job parts you need will be lights,front grill front bumper and bumper support bar,wheel archer's and you need to trim the front wings down ( behind headlights) also rewire the headlight plugs.
You will loose the automatic headlight up and down ( for when towing to stop blinding oncoming drivers )
if you need any help just pm me 😉
Thanks Ash
Post #100387 5th Jan 2012 12:50pm
daveo
hi, looks like you should have asked a few questions before you started.. you will need more then the lights and grill, you will need bumper, bumper frame, headlight plugs,air filter and you will need to mod the front wings V8 facelift Range Rover Autobiography 22" wheels.
Post #100456 5th Jan 2012 8:19pm
