![]() | Home > Technical (L322) > Scissor type ball joint separator |
ric355 Member Since: 02 May 2011 Location: Surrey, UK Posts: 302 ![]() |
Have you tried the 'two hammer' method first?
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3987 ![]() ![]() ![]() |
The other cheap way is to undo the nut but leave it on, use a lever to put tension on the ball joint and hit the side of the ball joint with the obligatory hammer.
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1558 ![]() ![]() |
Personal experience is that if you've gone to the bother of getting the thing apart ( or are going to the bother of splitting it ) you may as well replace it anyway. V8 or else ... |
AndrewT Member Since: 20 May 2011 Location: Auckland Posts: 97 ![]() ![]() ![]() |
Tried the 2 hammer method but it's jammed solid. Even applied some solid leverage and the 2 hammers but it really doesn't want to move. It's a method that's always worked for me in the past but have people had success with the hammer method on a FFRR lower ball joint?
I've never used a splitter, nor have I used the two hammer method as it would be just too fiddly, single 4lb lump hammer and one sharp blow on the eye of the joint should get it loose.
Landrover Mad Member Since: 04 Jan 2011 Location: N.Ireland Posts: 35 ![]() ![]() |
Hi,
klf400 Member Since: 10 Sep 2011 Location: forest of dean Posts: 210 ![]() ![]() ![]() |
works for me too 1990 3.5 v8 defender 2000 4.6 v8 30th anniversary prins lpg 2004 4.4 v8 vogue prins lpg 2011 4.4 TDV8 Vogue faultmate extreme rsw allcoms Autel 906BT Gap iiD tool |
