![]() | Home > Technical (L322) > Range Rover Classic 1981 3.5l Carb - Loss of power |
A1GSS Member Since: 24 Dec 2010 Location: Saffron Walden, Essex Posts: 1973 ![]() ![]() |
Carbs. Blimey. Long time since I thought about those... Strombergs I think they were.
speedymarktd6 Member Since: 20 Nov 2008 Location: Worcestershire Posts: 727 ![]() ![]() ![]() |
You should balance the carbs with a carb balancer gunsons make one but any one will do atleast you will know that they are sucking together onto no6 Range Rover
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1481 ![]() ![]() |
Carbed V8 ... my favourite! luv em.
Wow, great post. |
TugRR Member Since: 11 Jan 2011 Location: Bakewell Posts: 1200 ![]() ![]() |
Hi there -
Oh yes, I had that on my Triumph Herald... dim memories come flooding back of roadside repairs and AA Relay... Graham
myvatn Member Since: 20 Oct 2010 Location: Munich Posts: 80 ![]() ![]() ![]() |
![]() see this additional overview how the carbs are working ![]() |
Last bit of saddo knowledge ... The beaty burble of the rover block comes from having the firing order such that there are 2 times where the cylinders on the same bank fire one after the other rather than on alternate banks. This creates a double pulse of exhaust gasses down the exhaust manifolds whic by the time it reaches the end creates the 'beat' of the rover v8
RuiF1 Member Since: 07 Jan 2012 Location: Australia Posts: 4 ![]() ![]() |
Thank you very much for all your answers.
if you check the carbs have a look to the diaphragms, no need of special tools and easy to change
Nick Ground Member Since: 27 Dec 2011 Location: Dorset Posts: 584 ![]() ![]() ![]() |
Guys,
I second what Nick Ground has previously said.
Going by your sand escapades, the a clean of the carbs sounds a good idea.
Ok ... prepare to have yer mind blown ...
