![]() | Home > Technical (L322) > air suspension troubles |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35858 ![]() ![]() |
i'd leave it for a while to let the ecu;s sleep then raise and lower through the access,standard and high modes...it might just [hopefully] be a glich... ... - .- -.
RR8701 Member Since: 11 Aug 2011 Location: East Ayrshire Posts: 380 ![]() ![]() ![]() |
Scarey,
Reformed Member Since: 09 Oct 2010 Location: South Posts: 471 ![]() ![]() |
I did that earlier when it first happened. It was after reconnecting it that it came to life and went lop sided!
i think the battery dis and re-connect and lock to lock should be the first thing you should do if presented with suspension problems..and of course the condition of the battery should be considered..
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 ![]() ![]() ![]() |
Probably a dodgy height sensor. Check the arm hasn't broken. Quite a cheap and easy fix if I remember right. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
My thoughts are along with a dodgy height sensor as it seems to me, the computers are not sure where the car is sitting so it doesnt seem to do much now, allthough I would have thought it would give me an error either on the dash or when I plugged in the RAC all comms.
Its now booked in with the indie on Wednesday to be looked at. He seems to think it something like a height sensor, allthough from what I can see, they dont look damaged, and the fact there are no error messages.
Have you tried driving it a few hundred yards to see if it settles in the correct position. They sometimes need to be moved for the sensors to pick up the proper readings. |
Yesterday I drove back to my house from Portsmouth, which is about 10 miles and it stayed like it all the way.
Does it raise up to high setting? If so leave it running in the off road mode and lift the front wing slightly by standing with your back to the wheelarch and lift carefully and listen for a hissing... Maybe a punctured front bag at the top point of travel... Have seen it before and in normal height it gets all confused as it can't maintain correct pressures... Maybe sounds odd but I've seen it a few times now... Remember to check both sides...
Well my indie hooked it up to the computer in between jobs this afternoon and was some what baffled at the lack of fault codes, there was nothing on any modules!
![]() reminds of a hot wheels toy car lol On a serious note, I dont see how the compressor would only affect the rear susp and not the front, very unlikely. could it be a faulty ECU moduale ? Have you have HDC inactive errors at all? implicating it might be a battery issue ? |
No errors at all, and I have recently changed the battery. He is not saying that the compressor isnt working as such, it could be an electrical fault, short on a wire, module linked to the compressor ect. but it appears to be linked to the compressor.
You were correct Craig, the front right airbag is leaking, as quick as it fills it comes out!
