Home > Maintenance & Mods (L322) > rear Wheel bearings
npikey
United Kingdom 2006 Range Rover Vogue SE Supercharged Java Black
rear Wheel bearings
on 4.2sc mine have a little play and will need replacing soon, any tips and are they a biatch to do,
Cheers Nick Wink
Post #101310 12th Jan 2012 11:49am
A real butch
Post #101313 12th Jan 2012 12:17pm
npikey
Oh great, thanks Sad
Post #101581 13th Jan 2012 4:34pm
Need to remove the complete hub assembly by removing top rose bush and bottom bush bolts and driveshaft. A press is required to change the bearing. Whilst off you are best changing top rose and bottom bushes as they are not expensive. Mark the top bolt as it is eccentric and has to go in exactly as it comes out for the wheel alignment. Driveshaft can be a real swine to remove, sometimes easier removing from the diff end or use an air chisel with blunt tool to press out
Post #101599 13th Jan 2012 5:23pm
Garage job Cool Discovery 4 HSE
Post #101616 13th Jan 2012 6:27pm
Garage job if you're not confident. I only discovered a knackered wheel bearing by chance when changing the rose and bottom bushes. Unfortunately I don't own a hydraulic press so I just stripped the hub off and took it to my MOT man who pressed out the old bearing and pressed in the new one. Bearings are not expensive from LR, around the £26 mark
Post #101617 13th Jan 2012 6:42pm
Sorry to bump a thread from the dead Smile
But would some form of 3 pronged push be able to shift the driveshaft out of the hub, like a wind in one?
Like this maybe??
http://www.off-road.com/images/content/8-T...-16-15.jpg FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #406062 23rd Sep 2016 4:22pm
My driveshaft was stuck solid in the hub, it wouldn't budge and I ended up removing the entire shaft with the hub assembly as an entire unit and taking it to my local mechanic who did a lot of cursing and swearing before it eventually parted.
Post #406082 23rd Sep 2016 6:53pm
I'm guessing it was a good chance to change the diff oil then? Was a new seal needed for the end of the shaft at the diff end? FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #406088 23rd Sep 2016 7:08pm
No
Post #406101 23rd Sep 2016 7:52pm
Ooo that's interesting I would have expected it to dribble it some. May as well do it while I'm under it though considering the cost of the fluid isn't much I suppose.
Strange how I've become even more fussy and a simple job turns into more and more bits being done lol FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #406159 24th Sep 2016 10:49am
