![]() | Home > Technical (L322) > FBH runs for 2/3 mins then stops? |
rwilson Member Since: 17 Jan 2011 Location: London Posts: 84 ![]() ![]() ![]() |
I can activate it via remote (new batt), it starts, fan comes on, I can hear the burner noise from the nsf arch then it stops.
Rambles Member Since: 16 Apr 2011 Location: UK Posts: 846 ![]() ![]() |
still on OEM battery?
A1GSS Member Since: 24 Dec 2010 Location: Saffron Walden, Essex Posts: 1973 ![]() ![]() |
Mine turned out to be a faulty FBH ECU. Have you got access to a tool to read the fault codes? Graham
yep still on OEM |
dont have access to a fault code reader. |
2009 .. unless you're VERY unlucky (jan 1st - Jan 12th registered) your car still under warranty. Get it into the dealer PDQ. Mine cost £1400 to fix... Graham
DOR June 09 so till in warrenty |
Only answer. They're very expensive parts, and no LR servicing bits inside, so it means a new one. Graham
As Graham says...
![]() RRC 2Dr, RRC 4Dr, P38, and 2 L322s (wife thinks I'm nuts - prob right, too) |
Car booked in for thursday, i'll let you know what happens. |
Jr-auto-electrics Member Since: 15 Jan 2012 Location: West Midlands Posts: 189 ![]() ![]() ![]() |
Sounds same as mine,
Popped it in to Lookers Battersea, they were very helpful. Its going back next wednesday for a day!!!
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3261 ![]() ![]() ![]() |
And what was the outcome Mr Wilson?? |
