Home > Technical (L322) > Front suspension thump |
HAve you checked for anything loose under the wheel arch liner? |
13th Jan 2012 11:02am |
rads Member Since: 04 Sep 2011 Location: Herts Posts: 157 |
I really can't see why the suspension should need to be calibrated.
13th Jan 2012 11:26am |
New height sensors do have to be calibrated |
13th Jan 2012 11:46am |
Glideman Member Since: 11 Sep 2011 Location: Stood next to a broken down Range Rover in Darwen Posts: 112 |
I've had the liner out on the side with the knock & it's all tight Range Rover 4.4 V8 Vogue |
13th Jan 2012 11:48am |
Original height sensors used, so no calibration.
13th Jan 2012 12:02pm |
Just been watching this and maybe this could be it http://www.rswsolutions.com/index.php?opti...;Itemid=78
1st Feb 2012 7:13pm |
brantly Member Since: 30 Mar 2010 Location: oxfordshire Posts: 2 |
Sorry to bother you but I have just been reading your posts from a few years ago and am also on the verge of a nervous breakdown due to incessant knocking from my Range rover suspension . Out of interest did you ever discover what it was as I to have changed just about every bush and link and still I have a noise which is getting progressively worse. Any help would be greatly appreciated cheers Neil |
16th Sep 2015 4:07pm |
In typical FFRR fashion the one knocking is the one you never changed, but by the time you find out which one is knocking and change it all the others that you already changed will need changed again |
16th Sep 2015 4:09pm |
No, thousands of ££££ later and still knocking Range Rover 4.4 V8 Vogue |
17th Sep 2015 12:41am |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2026 |
have to admit to not ready through this entire thread, but i have had on a couple of older cars, a problem, with the swivel bearing on the top of the front suspension strut, at the point where you can tighten, on top of the strut top under the bonnet, there is i think a cover you ping off to reveal a bearing and a sort of allen key socket. im not near my car at moment. too late going to bed now... i think a new strut goes through this bearing. you would need someone to bounce car really properly while you feel for any play. i dont remember what you call these, but they bolt to the strut and then three nylocs hold them to the inner wing
17th Sep 2015 1:47am |
Glideman!
17th Sep 2015 8:49am |
Shh.
21st Dec 2016 8:35pm |
Didn't want to jinx it in December, but nearly a 87,000 miles and over 5 years since I started this thread, I can confirm that my thump has definitely gone.
I think this is spot on. When I started shotgunning bits at it, I bought the cheapest parts available, thinking there would be little variation in quality. Not sure that was sensible. My gut feel now is that the struts can knock. Looking back at the thread, first set of lower joints did not fix it, but I reported a definite improvement (not perfect) when I put the first strut on. I now think that strut knocked, but over the years and 1000s of miles the new (cheap) lower joint wore out, so when I put the second (OEM) strut on, the knock didn't go as it was now also the joint. Finally, when I pit the second (OEM quality) joint on, all sources of knock were fixed. I've taken a decision to not buy the cheap pattern parts anymore. In summary, if chasing knocks I would suspect drop links first (had three sets of these now, but really easy to diagnose and fix), then the lower ball joint, but if nothing else obvious, by very suspicious of the struts, particularly if they may be non-original. David |
13th Jan 2017 3:19pm |
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2180 |
Wow mega thread - I have a near side light knock on mine all looks good underneath but struts are original so will be ordering some Delphis… if this doesn’t fix it I will get the ball joint and links too. Very insightful Current stable:
18th Aug 2021 11:26pm |
