![]() | Home > General > Private registration.... |
^^^ Yes you're looking better now |
I had a right row with a local WPC plod about my short plates... She went back to the station to check with traffic dept and had her and her SGT ring and apologise as they are as i thought completely legal as there is no minimal size for width. Just so long as it has the same size gap as the bottom on the sides...
Tomw2000 Member Since: 22 Jan 2011 Location: Hertfordshire Posts: 202 ![]() ![]() |
+1 this. Not worth the risk imo. |
Johnte Member Since: 23 Aug 2010 Location: North Yorkshire Posts: 745 ![]() ![]() |
Craig, I like the look of the 'short' plates. I was thinking of putting this one on mine (I have it on retention at the moment) What did you do at the back - did you go short, or full size RR?
Can i have your disco plate please!!!!!!!!!!!!!!
Must admit, would look better on Disco, that's what I used to have it on (and that's why I haven't put it on FFRR before now)
trafpol Member Since: 15 Jun 2011 Location: Surrey Posts: 141 ![]() ![]() ![]() |
There is no law on width of plate but there is on size and shape of each letter or number AND there is a set distance between each one. Take ABC 123 D......The space between ABC has to be constant, space between the C and 1 is larger, 123 has to be constant etc.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35834 ![]() ![]() |
as said above the letters and numbers must be a standard size and all number plates must adhere to british standard BS AU 145d which must be marked on the plate, along with the name and postcode of the manufacturer and the supplier of the plates. ... - .- -.
Believe it or not you can also have black plates on vehicles above 7.5 tonne too! Dont know why? but its in the regs!
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3983 ![]() ![]() ![]() |
^^^^ Are your plates not illegal? |
Who's mine?
Yes |
N.D.F.I., if they're ''not illegal'' then they must be legal... |
