![]() | Home > General > TPMS Tyre valve broken by dealer |
Andy_J Member Since: 14 Nov 2011 Location: Muir of Ord Posts: 479 ![]() ![]() ![]() |
Hi All
Thanks alanm_3
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6822 ![]() ![]() ![]() |
I'm not sure about the legal position, but as a dealer they'll have been aware of the fragility of them and perhaps warned you upfront that they might break during investigation?
Not the first time I have had ham fisted work from this dealer, but no one else local. A few years ago they sent me home in my TD5 Discovery after cracking the oil rotor filter housing so the disco emptied most of its oil onto the exhaust. I have had 14 loose wheel bolts after a service as well (you could take them off with your fingers 56 TDV8 Vogue SE
And you went back???? |
no where else up here with the diagnostic kit. As soon as I can afford IID, Hawkeye or Faultmate I will be doing the servicing myself 56 TDV8 Vogue SE
JustinP Member Since: 24 Oct 2010 Location: Cambridge Posts: 889 ![]() ![]() ![]() |
When Marshalls of Cambridge damaged my wheel attempting to remove a stubborn locking wheel nut, they repaired the damage at their cost.
That is the reason I generally avoid garages.....'sorry sir we broke..... parts......our incompitance will now cost you £££££' Translates to 'We were a bit short of work so we broke something expensive on your car and will now bill you for it' Can't work out how they broke the valve when taking the tyre pressue as I do this weekly without breaking the tyre valaves 56 TDV8 Vogue SE 9 Freelanders, 2x 2002 TD4ES, 2001 TD4, 2002 1.8GS, 2000 XEDI, 2x 2000 1.8ES, 2004 1.8 & 2000 1.8 GS (rolled) 91 Lotus Carlton (sold) 90 Lotus Elan (BRG) |
Paul J. Member Since: 13 Jan 2009 Location: Leafy Cheshire Posts: 280 ![]() ![]() |
One of my valve stems crumbled as I was checking the pressure - quite unnerving to think what could have happened if it had given way on the motorway.
The RR is going back to the garage i bought it from this saturday for them to investigate a problem with the HVAC not blowing air up the windscreen and to investigate the TPMS on the road wheels not working, so i will discuss the spare with them.
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8063 ![]() ![]() ![]() |
![]() ![]() The TMPS valves are crap - I had one go on me when I was checking the tyre pressures - it basically just blew the centre out and went flat in seconds. Typical that it was the night before I went on holiday and the boot was stacked to the roof ![]() |
My first experience of Marshalls was with the sales team and it was |
