![]() | Home > Technical (L322) > Heated screen only half working |
Johnte Member Since: 23 Aug 2010 Location: North Yorkshire Posts: 745 ![]() ![]() |
I think the elements or 'lines' within the screen break and stop heating up. At least the drivers side still work at the moment |
Find a stone chip, call your ins co. Say the chip is stopping the heated screen from working. They will replace the screen for the £50-£70... The lady I spoke to said they always recommend replacement screens on heated screen vehicles rather than resin injection. |
BrianC Member Since: 15 Apr 2009 Location: central belt Posts: 1429 ![]() ![]() |
is there 2 fuses for the heated screen ? normally heated screens are 2 seperate circuits |
CarMan Member Since: 03 Dec 2011 Location: Cotswolds Posts: 105 ![]() ![]() |
Apparently there are 2 fuses but just a few strands on the left are working plus all the right side so it's not that. Booked it into my local dealer before Christmas and they tell me it needs replacing but it's not covered under warranty. Cost is nearly £700 so I phoned the supplying dealer who very helpfully suggested I call LR warranty, who advise me it is covered. How does that happen! Anyway, the news is more positive. |
In case it helps anyone else - although glass is excluded from the LR extended/used warranty it is an electrical fault with the windscreen itself and therefore covered. My local independant dealer has now been authorised to replace tomorrow I understand |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6827 ![]() ![]() ![]() |
I used mine the other day for the first time, and sod's law says it's the drivers half the doesn't clear, so can anyone point me towards which fuses the screen uses? Got - 2017 SDV8 Autobiography in Loire Blue
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6425 ![]() ![]() |
Handbook indicates only one fuse No. 47 (30amp) up front. |
That'll be that then! |
I am certainly no expert but I have been told by two dealers that the screen has 2 fuses |
There is also mention of the relay:
Mikeyjd Member Since: 14 Jun 2011 Location: Wrexham Posts: 543 ![]() ![]() ![]() |
Mine clears on the left, and a couple of narrow bands in the middle, but the drivers side doesn't work |
Jr-auto-electrics Member Since: 15 Jan 2012 Location: West Midlands Posts: 189 ![]() ![]() ![]() |
Hi
Andy Member Since: 24 Feb 2009 Location: Shropshire Posts: 2947 ![]() ![]() ![]() |
Mine doesn't work on the drivers side either. Strange. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
