![]() | Home > My Range Rover > TD6 to a TDV8 - And hello! |
bozmandb9 Member Since: 06 Dec 2010 Location: Wallingford, Oxfordshire Posts: 1055 ![]() ![]() |
Hi and welcome, and congratulations.
A1GSS Member Since: 24 Dec 2010 Location: Saffron Walden, Essex Posts: 1973 ![]() ![]() |
UK spec TDV8s have the pre-heater. If you don't have the fob then a previous owner has made off with it. Graham
wistles Member Since: 18 Jan 2012 Location: UK Posts: 9 ![]() |
Thanks. So can I work it without the fob? Or is this something I need to buy and have coded? "ducks for cost" |
AFAIK you can set it through the touchscreen to come on and off at preset times ... |
Correct for the cabin heater; you also have a "manual" mode (ie "heat now").
That is what I miss. Opening the door a crack, pressing the fob and coming out 20 minutes later to a warm car ready to go. Do you know how much a replacement fob is and whether it needs to be coded? |
Does need to be linked to the car but there may be a user way of doing it, don't know. Dan at Duckworth (site sponsor) can supply the fob. Graham
If you buy a remote Fob , i am sure your local Stealer will activate it , although it might be at a small charge |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3805 ![]() ![]() |
opening the door??? ![]() I prefer to sit by the roaring fire in the pub and hit the button ![]() |
I never found out how far it worked from! |
60 metres i think ... |
Webasto claim 500m i think but certainly a lot farther than you think. 2008 MY Supercharged
I am now Range Rover less. The entire car broke down on Friday night. This coupled with a few other problems made me reject it. Saxtons originally did not want to know (I only had the car for 5 days) but I persisted and they caved, shocking service from them. |
piecost76 Member Since: 19 Jul 2010 Location: Nr Sevenoaks, Kent Posts: 296 ![]() ![]() |
Another thumbs up for Saxton 4x4 then |
