![]() | Home > Technical (L322) > FBH Not working on my TD6 Help! |
Jr-auto-electrics Member Since: 15 Jan 2012 Location: West Midlands Posts: 189 ![]() ![]() ![]() |
Is your battery ok paul b,
Renegade2 Member Since: 03 Dec 2011 Location: Cardiff Posts: 134 ![]() ![]() ![]() |
Checked battery which was low so put my MXS10 on overnight, battery is fine now but has not made any difference to the tocuhscreen menu, on timed fans come on no fbh, press the manual soft key no fans or fbh.
Just to compare is there any one else with the same spec car
Just looked at my copy of rave,
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3983 ![]() ![]() ![]() |
This may be of use to you.
Cheers nice day for it
Hi JR
PaulB Member Since: 17 Jul 2011 Location: Hampton Posts: 877 ![]() ![]() |
i have exactly the same as above...... |
Paul i think landrover put there to tease us!!!! |
I just read tis on another thread which i wonder if this is the reason that mine and Paulb fbh does not switch on from the touchscreen
Hi
M.D.610 Member Since: 01 Dec 2011 Location: Trier Posts: 44 ![]() ![]() ![]() |
Just been outside to try this manuel system on the timed climate control and the same thing started happening just venting cold air.......then all of a sudden it worked for about 10 seconds then everything went off tried starting the car flat battery within 10-15 mins so leads me to think the battery has had ists day and from what I can gather through this site the FFRR seems to be very sensitive to battery faults time for a new one ........ but what is recomended theres a whole heap of batteries out there!! 12v but what amperage is recommended? I don't know what is on it at present that I can check in the Morning but maybe it is the wrong one for the job!!
Hi JR No remote control. but I noticed I had to set the temp setting knob to full (both sides 26 degress I think) and the auto button in the middle had to be active then it worked but very briefly the battery went dead. I think it's time for a new one!! on reflection I just remembered before this business with the FBH I was refitting something or other and within 15--20 mins the battery was flat, had to borrow my neighbours jumpleads i understand the FFRR is susceptible to battery errors call it what ya will NEW BATTERY REQUIRED...................BUT HOW BIG 12v /100-120 any info welcome....... my landy man dealer/stealer is chuffed with me I'll tell ya!! Current stock:- FFRR Vogue |
http://www.battery2u.co.uk/type-I1-varta-car-battery-silver.aspx
