![]() | Home > Technical (L322) > Help, really bad shake |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16369 ![]() ![]() ![]() |
Have you cleaned out any large amount of crud from the inside of your wheels? I had the same symptoms when mine filled up with snow and ice!
chim Member Since: 11 Jan 2012 Location: Ayrshre Posts: 11 ![]() ![]() |
There was loads, cleaned out and hoped that it was fixed, has improved as was shuddering from about 30 but still badly shuddering over 50. RRFF 2007 |
speedymarktd6 Member Since: 20 Nov 2008 Location: Worcestershire Posts: 727 ![]() ![]() ![]() |
have you lost any of the ballance weights on your wheels onto no6 Range Rover
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35770 ![]() ![]() |
you've lost the stick on balance weights from the inside of the wheel.. ... - .- -.
To be honest I would be very surprised if i did not lose some, was a bit dark to check and will look in the morning. she ended up completely buried in the mud and was doing a lot of rocking her back and forth to try and get free. Given the size of the wheels would you expect a teeth rattling shudder if just a balance problem, no other symptoms of problem (no noise etc) RRFF 2007 |
btw, seeings you have 22'' i would check for cracks in the alloy.. ... - .- -.
will check for cracks, had a good look when I was jet washing though and the seemed OK. Anyone know if there are any wheel shops in Ayrshire that can balance 22 inch rims RRFF 2007 |
