![]() | Home > Technical (L322) > 2010 REAR LIGHTS |
what about the side light/ fog light issues V8 facelift Range Rover Autobiography 22" wheels.
oodathort Member Since: 01 Nov 2010 Location: just there Posts: 191 ![]() |
Hi what sort of issues regarding fog lights |
well the side lights and fogs use the same led's but there is a voltage difference to make them dim for side lights and brighter when fogs are used V8 facelift Range Rover Autobiography 22" wheels.
Yes sort of its correct that there is around 4 volts on the fogs all the time however the fogs and side lights are on seperate feeds so all you need is a relay on the fog feed
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16369 ![]() ![]() ![]() |
Ide like a set or two please if they work... i'll pm you my number...
+1 i would like a set as well |
Hi Guys not a problem but this is only the dissco effect issue if you need help with the fogs i can help you with how i got over the problem
Jr-auto-electrics Member Since: 15 Jan 2012 Location: West Midlands Posts: 189 ![]() ![]() ![]() |
Or if you would like a kit to fix all your issues
Hi what does your kit cost and does it encompass all issues
Hi
Cost ? |
oodathort, can you pm jr electrics re cost please... ... - .- -.
Martin Site Admin Member Since: 24 Mar 2007 Location: Hook Norton Posts: 1673 ![]() ![]() |
Commercial Posting - i.e. using this site to promote or sell items - is NOT allowed unless you are a sponsor, via PM or otherwise.
