![]() | Home > Technical (L322) > Strange electrical gremlins. HELP! |
muffster Member Since: 03 Dec 2011 Location: Bradford Posts: 71 ![]() ![]() |
Ok thanks for the info there mate.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35770 ![]() ![]() |
might be ok for a petrol but the td6 needs more ooomphhhhh.. ... - .- -.
Hi again folks.
did you set the steering parameters after putting the new battery on, if so you might have to get a dealer to read/clear some codes .. ... - .- -.
No mate could you elaborate on that please.
dis-connect the battery, leave for an hour or so and re-connect....start the engine and then turn the steering wheel fully left then fully right, this sets the steering parameters and in most cases gets rid of that error.... ... - .- -.
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6424 ![]() ![]() |
"keeps losing power" ??
Yes mate it selects gears ok. Am hoping its electrical. Will try and get to an auto electrician at the weekend. Hopefully the gearbox is ok!!! |
Ok the warning hasnt come on again for a while.
mercs600 Member Since: 19 Mar 2011 Location: North Yorkshire Posts: 425 ![]() ![]() ![]() |
I had exactly the same on my TD6 last year and it turned out to be water ingress in the rear left hand side and was shorting the plugs out on the TV unit , amps etc. Took all plugs off all electrical equipment and dried and cleaned and it cured all those issues (oh and my battery was also 3-4 months old). Good luck |
Also check your selector is working properly. Check the wiki for this.
farrellelion Member Since: 05 Jul 2011 Location: Oliveira do Hospital Posts: 22 ![]() ![]() ![]() |
As Joe 90 says,you many be lucky with an oil change and flush, but I'm sure your gearbox is stuffed- probaly will need overhaul or replacement, within 6-9 months, if not sooner.
I had a puncture yesterday so was in the spare wheel well and found it was soaking. Only in the well itself. i couldn't find any signs of ingress so had a look around and couldn't find anything. After 5 + years of ownership i havn't had any problems like this, the car has always been garaged, with the exception of the last 3 months. (one of the mirrors is broken so won't fold in and fit in the garage!!!) So can you tell me where it is coming in and where exactky do i need to look. Thanks for the replys. |
