Home > Technical (L322) > Rear calliper v's handbrake shoe
stenh02
Scotland 2004 Range Rover Vogue 4.4 V8 Rimini Red
On my 2006 S/C I have a warm rear offside wheel after driving and occasional on-road vibration.
Thinking it was a binding caliper I had the wheel off last night, took off calliper and pushed piston in back. When remounted calliper it was free to move side to side, pumped the foot brake and the slack was taken up.
Driving to work today no vibration or brake squeak but that offside rear wheel was still warmer than the others.
Pads looked good in condition and disc was clean and shiny.
I didn't take the hub off to check the park brake springs.
Is there anything I should check before getting a new calliper?
I thought wheel bearing would cause noise before it got to the 'heat' stage.
Cheers,
Grant
Post #103312 24th Jan 2012 3:14pm
bozmandb9
2013 Range Rover Vogue SE TDV8 Causeway Grey
Re: Rear calliper v's handbrake shoe
I had a caliper bind, it was the nearside on mine, and I didn't realise until the pad had worn through! (No wear sensor on rear n/s). Apparently it's a common problem on 2006 models! 2012 SDV8 Vogue SE
Post #103315 24th Jan 2012 3:21pm
speedymarktd6
United Kingdom 2010 Range Rover Vogue SE TDV8 Santorini Black
Had to do mine also n/s new caliper problem solved onto no6 Range Rover
Everyone needs a hobby
Post #103351 24th Jan 2012 6:40pm
