Home > General > Service Indicator Info
rich_959
United Kingdom 2007 Range Rover Vogue TDV8 Stornoway Grey
Folks,
Just been thinking..... (dangerous, I know) that my service indicator should really have been on by now based on the mileage and the last service date. Is there any way of bringing up the info, prior to the time when it would normally come up on the dash?
Had a quick search to avoid repeated topics but couldn't find anything...
Post #103463 25th Jan 2012 12:54pm
My '02 tells me the mileage countdown once I flick on the ignition. It stays there for a few seconds and then disappears.
This is in the LED information area below the main instruments.
This is as per the IOM that I read last weekend. Si. <This is my name.
Post #103467 25th Jan 2012 1:53pm
rich_959
Bellini - my Disco did the same, once you got within a certain mileage or number of days, but not if it was a long way away.
Scarey - what year is yours? I'll have to look into the dash check thing. I may have to do the unthinkable and consult - THE MANUAL Shocked Noooo!
Post #103472 25th Jan 2012 2:15pm
Fr_Raf
France 2004 Range Rover Vogue 4.4 V8 Java Black
On my MY04 model, the dash tells me remaining kilometers untill next service, and date of last reset
Post #103474 25th Jan 2012 2:18pm
Andy_J
Scotland 2007 Range Rover Vogue SE TDV8 Java Black
Never seen a message on my 56 plate TDV8 when I turn the ignition on, I was going to ask the same question 56 TDV8 Vogue SE
9 Freelanders, 2x 2002 TD4ES, 2001 TD4, 2002 1.8GS, 2000 XEDI, 2x 2000 1.8ES, 2004 1.8 & 2000 1.8 GS (rolled)
91 Lotus Carlton (sold)
90 Lotus Elan (BRG)
Post #103475 25th Jan 2012 2:21pm
Googsy
Apparently intervals vary depending on how car is driven. I believe the interval is about 15K . But I always get serviced at 12K or every year which ever comes sooner. Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Discovery 3 HSE
Gone Mercedes CLK
Gone Range Rover 2.5 DSE
Post #103476 25th Jan 2012 2:23pm
rich_959
googsy - I'm in the same boat. Coming up to 1 year and about 10k miles since the last service so expected to hit some sort of service countdown by now. Will get it done at the 12 month interval anyway, but was just interested to know how far 'the system' thought I was from needing a service.
Post #103479 25th Jan 2012 2:50pm
Googsy
I think it only appears at about 500 miles to service or something like that. Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Mercedes CLK
Post #103500 25th Jan 2012 7:01pm
It is different depending on age of vehicle. the 02 - 05 model shows miles left to next service when you start the car, later models only show you when "when its time" Wink AFAIK .
Post #103502 25th Jan 2012 7:13pm
33CHINACARS
Australia 2017 Range Rover Autobiography SDV8 Santorini Black
MY05 is in countdown mode for a few seconds when ignition is turned on. When I last looked it was at 6500km
Gary
Post #103657 26th Jan 2012 2:43pm
Cappo
2006 Range Rover Vogue 4.4 V8 Java Black
So, as above, is the average interval around 15k miles? Mines done 12k or more since the last service, nothing on the dash and the handbook says "service in accordance with the service indicator" or similar - so I'm thinking it must be pressing on for service time but not sure when!
Post #120169 3rd May 2012 7:24pm
stu
i had mine serviced on wednesday and it started showing on the display last week.
all it said was "Inspection 05/2012" Current: TDV8 (3.6) RRS HSE
Past: TDV8(4.4) Vogue
Discovery 3 Commercial
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #120310 4th May 2012 5:53pm
manfrommissenden
2006 Range Rover Vogue Td6 Cairns Blue
Gents
My 06 TDV6 RR Vogue has gone 15K miles and 20 months without any service indicator showing up and I too am a bit worried about whether a service might be overdue - no indicator as of yet. I could book it in now but my service book does not make clear whether it is next due an inspection 1 or an inspection 2 and I'm quite keen to give the car the right service.
- When the indicator does light will it tell me which type of service is due?
- Am I right i thinking that the services roll through a sequence of oil service/inspection 1/inspection 2 and then restart that cycle?
- I have had a few battery issues in the last year. Am I right in assuming that the memory of how far to go to next service would not have been wiped by the car being without power during flat battery/battery replacement periods?
If I know that it will tell me at the appropriate time what service to do I will relax. Happy to get through Xmas without an unnecessary expense...
Many thanks for any tips
Post #226538 2nd Dec 2013 4:39pm
Manfrommissended,
The service intervals are
Oil, inspection 1, oil, inspection 2. And repeats. Will indicate what it needs.
If it has not called for it you obviously drive gently, the BMW system should calculate when the service is due, based on how the car is driven, they should have used long life oils at the service intervals, which can(though not totally advisable) last upto 2 years, however I'm pretty sure that servicing the car every 12 months would be recommended by most folks here as a minimum, which would give you changes at 7500 miles, even if it was just an oils change done at somewhere like f1autocentres.(with the correct oil)
Disconnecting the battery will not reset the service memory, that has to be done with a diagnostic tool. If you have the service book with the car look at the last 2 services and you should be able to work out what is due next Thumbs Up
It's what I do with the Skoda as that has long life oils and only calls for service every 2 years.....called for service=dealer, interim oil every 12 months=local garage parts supplied by me. There is nothing that can't be fixed with a hammer😜😜
Post #226587 2nd Dec 2013 9:20pm
Simple1
United Kingdom 2009 Range Rover Vogue SE TDV8 Santorini Black
Never do enough miles in a year to trigger it but it throws up a year warning counting down to due day from 50. I don't think you can call up the info in the interim period but I'm sure a grown up will be along to confirm this or deny it Thumbs Up TDV8 Vogue SE 2009.
TDV8 Sport. Gone. Loved it but it didn't love me!
Other toys in the cupboard.......
Post #226615 2nd Dec 2013 11:38pm
