Home > In Car Electronics (L322) > Parking sensor connectors and sensor loom to car connector |
stenh02 Member Since: 30 Jan 2011 Location: Somewhere not warm Posts: 340 |
Tom,
22nd Jan 2012 6:05pm |
tomthevet Member Since: 14 Jan 2012 Location: Scotland Posts: 283 |
Oh right so did it come apart in a way which would allow you to resolder new thicker wire to the terminals?? |
22nd Jan 2012 6:13pm |
The aperture the blade and wire go thru is pretty small and there is a yellow rubberised material at the end of the blade as a 'bung' that the wire passes thru.
22nd Jan 2012 7:05pm |
Fair enough. You did exactly what I did ie spliced in a new wire up to a few inches from the connector which is why I thought maybe you could rewire the connector itself.
22nd Jan 2012 7:19pm |
I might get a spare loom to play with. Am looking at this:
22nd Jan 2012 7:26pm |
stevegt Member Since: 17 Apr 2010 Location: Worcestershire Posts: 255 |
It depends what end of the car you rate on about. I believe only the rear sensors are on a separate loom as the fronts for part of the main engine bay loom and cannot be detached from the car without removing the entire thing. The sensor plugs do come apart but i do agree that they are a little on the flimsy side. 06MY 4.4 V8 Autobiography Cairns Blue with Navy & Parchment Interior |
24th Jan 2012 7:56pm |
Its the rear that gives me all the problems which does have a connector but cant for the life of me remember what it looks like
25th Jan 2012 1:33pm |
