Home > Technical (L322) > Heated rear window interference
Anyone else suffer from radio interference when they switch on their heated rear window ,
Anyone know what the cause would be or cure Thumbs Up
Post #103561 26th Jan 2012 9:07am
Faulty antenna amplifier
Post #103562 26th Jan 2012 9:08am
Cheers John , Thumbs Up
Post #103563 26th Jan 2012 9:09am
Not sure where it's located Mick, should be covered by warranty though. A common fault with Mercs
Post #103565 26th Jan 2012 9:11am
Will find out when I phone the stealers , as I need to book it in coz the camera on the near side mirror is faulty as well , friggin thing is a Fonty Car ..... Laughing Thumbs Up You'll get that being an old Glesga guy Laughing
Post #103567 26th Jan 2012 9:17am
Simes
United Kingdom 2011 Range Rover Autobiography Black TDV8 Barolo Black
Hi Mick,
Sometime interference when the heated window is on can be due to the heating elements breaking down on the glass, causing a 'noisy joint' - you'll here irritating white noise on the radio as the break in the heating element conducts - but only just. Had it a couple of times in cars in the past - a judiciously applied drop of the silver conducting paint stuff (Maplins) usually sorted it.
Post #103580 26th Jan 2012 10:06am
Olders
United Kingdom 2016 Range Rover Autobiography SDV8 Loire Blue
I have the same thing as well, quite irritating!
In my case however, it is more than a little white noise; it almost completely blocks out the radio signal. Could this be the problem you mentioned Simes or is a faulty antenna amp more likely do you think?
Mick, would love to know what the stealers say when you take yours in if poss? Thumbs Up
Cheers. -----------------------------------------------
2016MY FFRR 4.4 SDV8 Autobiography Loire Blue
2007MY FFRR 3.6 TDV8 Vogue SE Tonga Green
Post #103593 26th Jan 2012 11:38am
Simes
If you get a nice misty morning and the screen is very misted up, put on the heated element and watch for an area that clears quicker than the rest - usually in a circle around the dodgy part of the element... That's how I spotted it in the past.
Post #103609 26th Jan 2012 12:23pm
Stephen.125
2017 Range Rover SVAutobiography 5.0 SC V8 Indus Silver
@Simes: great advice Thumbs Up
Post #103610 26th Jan 2012 12:26pm
Have just been called by the dealer to let me know that they will be fitting a new Rear Screen under warranty as the car is at the dealers for to get a couple of faults sorted ... Thumbs Up ====================================
Post #107643 16th Feb 2012 4:00pm
