![]() | Home > In Car Electronics (L322) > When were the Mk4 maps last updated on the DVD ? |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35861 ![]() ![]() |
there is a 2010/2011 update available , mapping only no firmware update...... ... - .- -.
Simes Member Since: 30 Aug 2011 Location: Hinckley Posts: 964 ![]() ![]() ![]() |
I think there is a 2011/2012 DVD available from the usual suspects too now. |
my bad, yes it is the 2011/12 which is the latest.. ... - .- -.
Yes - Pull yourself together man... |
VaguelyVogue Member Since: 05 Feb 2010 Location: Buckinghamshire Posts: 380 ![]() ![]() ![]() |
Thanks - would satnavi be one of the "usual suspects" or should I be looking elsewhere ? |
just bought the 2012 map, will see if i can make a backup and let you know.. V8 facelift Range Rover Autobiography 22" wheels.
Renegade2 Member Since: 03 Dec 2011 Location: Cardiff Posts: 134 ![]() ![]() ![]() |
Scarey, I have not updated mine for a while what version do i need to get a firmware upgare and would i benefit form it? TD6 2005 with Touchscreen
you'll get newer mapping and some new bits on the screen and tbh of which i cant remember cos i upgraded mine when i got my range ...but you do loose the nav on the go function..
Oooh - I can sense a potential backup test - thanks Dave ! |
comports Member Since: 20 Dec 2010 Location: Colchester Posts: 1764 ![]() ![]() ![]() |
I'd be happy to test your backup as well Daveo..! |
Olders Member Since: 17 Mar 2011 Location: Suffolk Posts: 115 ![]() ![]() ![]() |
Question....
once you stick the 2009/10 disc in then you cant re-enable the nav on the go function, the new firmware takes care of that...
we are talking about the map for the mk4 unit, non touch screen.i was told that some early touch screens had mk4 units but have never seen it. V8 facelift Range Rover Autobiography 22" wheels.
